3rd party package build system
Nicolas Tsiogkas
lou.nick at gmail.com
Wed Sep 6 09:56:12 UTC 2017
Hi,
I'm trying to integrate SOEM with RTEMS (https://devel.rtems.org/ticket/3120
As I am trying to create the appropriate bset and cfg files I noticed that
all the packages built are based on autoconf to be built.
SOEM on the other hand is only providing CMake as a build tool.
I have found instructions on using CMake with RTEMS (
https://lists.rtems.org/pipermail/devel/2016-March/013800.html)
The question is if it would be more sensible to create a build environment
for SOEM based on autotools or try to use CMake somehow?
I doubt that changing the build system will be easily accepted upstream.
Any thoughts?
Cheers,
Niko
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170906/72a09b1c/attachment.html>
