[PATCH] posix: Ignore pshared for semaphores
Joel Sherrill
joel at rtems.org
Mon Sep 11 13:39:43 UTC 2017
On Fri, Sep 8, 2017 at 1:51 PM, Sebastian Huber <
> Ok, but why do you think that this is an error? We can share the
> synchronization objects among processes.
We don't have processes. How do you propose to share between
processes when RTEMS is fundamentally a single process system.
If you have found a way to change this, then there are other places
to adjust.
--joel
> ----- Joel Sherrill <joel at rtems.org> schrieb:
> > I have no idea how that is much clearer except that pthreads have defined
> > macros for scope and thus an invalid value is an error.
> > But POSIX isn't good at addressing error cases which existed based on the
> > profiles defined in PSE52-54. And those were not updated for POSIX 2008
> or
> > 2013
> > On Sep 8, 2017 10:16 AM, "Sebastian Huber" <
> > > > On Fri, Sep 8, 2017 at 8:33 AM, Sebastian Huber <
> > > > > Since we have only one process, sharing between processes is
> trivial.
> > > > > Close #3124.
> > > > > cpukit/posix/include/rtems/posix/semaphore.h | 1 -
> > > > > cpukit/posix/include/rtems/posix/semaphoreimpl.h | 1 -
> > > > > cpukit/posix/src/semaphorecreatesupp.c | 7 -------
> > > > > cpukit/posix/src/seminit.c | 1 -
> > > > > cpukit/posix/src/semopen.c | 1 -
> > > > > testsuites/psxtests/psxsem01/init.c | 14
> > > > > 6 files changed, 9 insertions(+), 16 deletions(-)
> > > > > diff --git a/cpukit/posix/include/rtems/posix/semaphore.h
> > > > > b/cpukit/posix/include/rtems/posix/semaphore.h
> > > > > index 45de4a93b9..6598397052 100644
> > > > > --- a/cpukit/posix/include/rtems/posix/semaphore.h
> > > > > +++ b/cpukit/posix/include/rtems/posix/semaphore.h
> > > > > @@ -43,7 +43,6 @@ extern "C" {
> > > > > typedef struct {
> > > > > Objects_Control Object;
> > > > > CORE_semaphore_Control Semaphore;
> > > > > - int process_shared;
> > > > > bool named;
> > > > > bool linked;
> > > > > uint32_t open_count;
> > > > > diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> > > > > b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> > > > > index 2bafbe9b97..43440298ec 100644
> > > > > --- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> > > > > +++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> > > > > @@ -78,7 +78,6 @@ RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control
> > > > > *_POSIX_Semaphore_Get(
> > > > > int _POSIX_Semaphore_Create_support(
> > > > > const char *name,
> > > > > size_t name_len,
> > > > > - int pshared,
> > > > > unsigned int value,
> > > > > POSIX_Semaphore_Control **the_sem
> > > > > diff --git a/cpukit/posix/src/semaphorecreatesupp.c
> > > b/cpukit/posix/src/
> > > > > index d66e1942c9..4a33336230 100644
> > > > > --- a/cpukit/posix/src/semaphorecreatesupp.c
> > > > > +++ b/cpukit/posix/src/semaphorecreatesupp.c
> > > > > @@ -42,7 +42,6 @@
> > > > > const char *name_arg,
> > > > > size_t name_len,
> > > > > - int pshared,
> > > > > unsigned int value,
> > > > > @@ -50,10 +49,6 @@ int _POSIX_Semaphore_Create_support(
> > > > > POSIX_Semaphore_Control *the_semaphore;
> > > > > char *name;
> > > > > - /* Sharing semaphores among processes is not currently
> supported */
> > > > > - if (pshared != 0)
> > > > > - rtems_set_errno_and_return_minus_one( ENOSYS );
> > > > Why are you deleting this error check? I can see not storing the
> value or
> > > > passing
> > > > it to create support. But I think it still should be validated. We
> only
> > > > support
> > > > requests for process private. Anything else is an error.
> > > Why is this an error? With only one process its easy to support sharing
> > > between processes. The text in the semaphore documentation is a bit
> vague.
> > > This description is a bit more clear:
> > > http://pubs.opengroup.org/onlinepubs/9699919799/
> > > functions/pthread_mutexattr_getpshared.html
> > > Sebastian Huber, embedded brains GmbH
> > > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > > Phone : +49 89 189 47 41-16
> > > Fax : +49 89 189 47 41-09
> > > E-Mail : sebastian.huber at embedded-brains.de
> > > PGP : Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
> EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170911/eec4ddea/attachment-0001.html>
