[PATCH] posix: Ignore pshared for semaphores
Mon Sep 11 14:03:04 UTC 2017
----- Joel Sherrill <joel at rtems.org> schrieb:
> On Fri, Sep 8, 2017 at 1:51 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> > Ok,  but why do you think that this is an error?  We can share the
> > synchronization objects among processes.
> We don't have processes. How do you propose to share between
> processes when RTEMS is fundamentally a single process system.
Yes, its a single process system. So, it is very easy to support sharing between processes. Why should creating a process-shared synchronization object fail only because its impossible to create a second process?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
