[PATCH] posix: Ignore pshared for semaphores
Tue Sep 12 14:04:20 UTC 2017
On 12/09/17 15:58, Gedare Bloom wrote:
> On Tue, Sep 12, 2017 at 1:10 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 11/09/17 16:03, Sebastian Huber wrote:
>>> ----- Joel Sherrill <joel at rtems.org> schrieb:
>>>> On Fri, Sep 8, 2017 at 1:51 PM, Sebastian Huber <
>>>>> Ok,  but why do you think that this is an error?  We can share the
>>>>> synchronization objects among processes.
>>>> We don't have processes. How do you propose to share between
>>>> processes when RTEMS is fundamentally a single process system.
>>> Yes, its a single process system. So, it is very easy to support sharing
>>> between processes. Why should creating a process-shared synchronization
>>> object fail only because its impossible to create a second process?
>> I would like to remove this process-shared error also from the other POSIX
>> synchronization objects:
>> https://devel.rtems.org/ticket/3125
>> https://devel.rtems.org/ticket/3126
> Do these process-shared synch objects work properly when used in a
> single process on *nix?
Yes, this is why I referred to the POSIX mutex documentation:
http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_mutexattr_getpshared.html
See also follow up (2.9.9 Synchronization Object Copies and Alternative Mappings):
http://pubs.opengroup.org/onlinepubs/9699919799/functions/V2_chap02.html#tag_15_09_09
Which explicitly mentions semaphores.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
