[PATCH 14/18] libio: Add rtems_libio_iop_is_writeable()
Wed Sep 13 13:39:47 UTC 2017
Update #3082.
 cpukit/libcsupport/include/rtems/libio.h | 10 ++++++++++
 cpukit/libfs/src/imfs/imfs_linfile.c     |  2 +-
 cpukit/libnetworking/lib/ftpfs.c         |  4 ++--
 3 files changed, 13 insertions(+), 3 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index 7d85fb7af3..72a787eebc 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -1400,6 +1400,16 @@ static inline bool rtems_libio_iop_is_readable( const rtems_libio_t *iop )
+ * @brief Returns true if this is a writeable iop, otherwise returns false.
+ * @param[in] iop The iop.
+static inline bool rtems_libio_iop_is_writeable( const rtems_libio_t *iop )
+  return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_WRITE ) != 0;
  * @name External I/O Handlers
diff --git a/cpukit/libfs/src/imfs/imfs_linfile.c b/cpukit/libfs/src/imfs/imfs_linfile.c
index 80a77c3ef8..a27ba99ede 100644
--- a/cpukit/libfs/src/imfs/imfs_linfile.c
+++ b/cpukit/libfs/src/imfs/imfs_linfile.c
@@ -56,7 +56,7 @@ static int IMFS_linfile_open(
    * Perform 'copy on write' for linear files
-  if ((iop->flags & LIBIO_FLAGS_WRITE) != 0) {
+  if (rtems_libio_iop_is_writeable(iop)) {
     uint32_t count = file->File.size;
     const unsigned char *buffer = file->Linearfile.direct;
diff --git a/cpukit/libnetworking/lib/ftpfs.c b/cpukit/libnetworking/lib/ftpfs.c
index deccddfa89..1e0f180fd0 100644
--- a/cpukit/libnetworking/lib/ftpfs.c
+++ b/cpukit/libnetworking/lib/ftpfs.c
@@ -1032,11 +1032,11 @@ static int rtems_ftpfs_open(
   bool verbose = me->verbose;
   const struct timeval *timeout = &me->timeout;
-  e->write = (iop->flags & LIBIO_FLAGS_WRITE) != 0;
+  e->write = rtems_libio_iop_is_writeable(iop);
   /* Check for either read-only or write-only flags */
   if (
-    (iop->flags & LIBIO_FLAGS_WRITE) != 0
+    rtems_libio_iop_is_writeable(iop)
       && rtems_libio_iop_is_readable(iop)
     eno = ENOTSUP;
2.12.3
