[PATCH] *** Covoar Windows Build Failure. ***
Thu Sep 14 02:23:07 UTC 2017
On 14/09/2017 01:45, Cillian O'Donnell wrote:
> *** The build is successfull if I run ./waf -v however the build fails on
> a normal ./waf command as it can't link to -lelf
>  4-mingw32/bin/ld.exe: cannot find -lelf
> Has anyone seen this behaviour before were it only builds in verbose mode?***
I am not seeing this.
> Cillian O'Donnell (1):
>   covoar: Add function defs to fix Windows build errors.
>  tester/covoar/DesiredSymbols.cc | 2 +-
>  tester/covoar/ReportsBase.cc    | 4 ++--
>  tester/covoar/TraceConverter.cc | 4 ++++
>  tester/covoar/covoar.cc         | 4 ++++
>  4 files changed, 11 insertions(+), 3 deletions(-)
Thanks. Pushed to master.
