[PATCH] *** Covoar Windows Build Failure. ***
Cillian O'Donnell cpodonnell8 at gmail.com
Thu Sep 14 10:24:16 UTC 2017
On 14 September 2017 at 03:23, Chris Johns <chrisj at rtems.org> wrote:
> On 14/09/2017 01:45, Cillian O'Donnell wrote:
>> *** The build is successfull if I run ./waf -v however the build fails on
>> a normal ./waf command as it can't link to -lelf
>>  4-mingw32/bin/ld.exe: cannot find -lelf
>> Has anyone seen this behaviour before were it only builds in verbose mode?***
> I am not seeing this.
Great! I was all out of ideas. Must be some local thing. I tried
Cygwin before MSYS2, maybe there's some stuff lying around from that
that's causing it.
>> Cillian O'Donnell (1):
>>   covoar: Add function defs to fix Windows build errors.
>>  tester/covoar/DesiredSymbols.cc | 2 +-
>>  tester/covoar/ReportsBase.cc    | 4 ++--
>>  tester/covoar/TraceConverter.cc | 4 ++++
>>  tester/covoar/covoar.cc         | 4 ++++
>>  4 files changed, 11 insertions(+), 3 deletions(-)
> Thanks. Pushed to master.
> Chris
