[PATCH] *** Covoar Windows Build Failure. ***
Thu Sep 14 22:20:32 UTC 2017
On 14/09/2017 20:24, Cillian O'Donnell wrote:
> On 14 September 2017 at 03:23, Chris Johns <chrisj at rtems.org> wrote:
>> On 14/09/2017 01:45, Cillian O'Donnell wrote:
>>> *** The build is successfull if I run ./waf -v however the build fails on
>>> a normal ./waf command as it can't link to -lelf
>>>  4-mingw32/bin/ld.exe: cannot find -lelf
>>> Has anyone seen this behaviour before were it only builds in verbose mode?***
>> I am not seeing this.
> Great! I was all out of ideas. Must be some local thing. I tried
> Cygwin before MSYS2, maybe there's some stuff lying around from that
> that's causing it.
Check your path and environment variables in the Systems Properties dialogue box
found under Control Panel's System.
