[PATCH] libio: Remove rtems_libio_t::driver
Fri Sep 15 11:05:33 UTC 2017
This member was apparently unused.
Close #3133.
 cpukit/libcsupport/include/rtems/libio.h | 1 -
 1 file changed, 1 deletion(-)
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index 804929915a..9d30dafddf 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -1318,7 +1318,6 @@ extern const rtems_filesystem_limits_and_options_t
  * to (eg: offset, driver, pathname should be in that)
 struct rtems_libio_tt {
-  rtems_driver_name_t                    *driver;
   off_t                                   offset;    /* current offset into file */
   Atomic_Uint                             flags;
   rtems_filesystem_location_info_t        pathinfo;
2.12.3
