[PATCH 1/3] posix: Allow PTHREAD_PROCESS_SHARED for mutexes
Fri Sep 15 11:58:04 UTC 2017
Close #3125.
 cpukit/posix/include/rtems/posix/posixapi.h | 15 +++++++++++++++
 cpukit/posix/src/mutexinit.c                | 10 +++-------
 testsuites/psxtests/psx05/init.c            |  9 ++++++---
 testsuites/psxtests/psx05/psx05.scn         |  2 +-
 4 files changed, 25 insertions(+), 11 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/posixapi.h b/cpukit/posix/include/rtems/posix/posixapi.h
index 1a64cf7a1d..2441a2ee6f 100644
--- a/cpukit/posix/include/rtems/posix/posixapi.h
+++ b/cpukit/posix/include/rtems/posix/posixapi.h
@@ -26,6 +26,8 @@
 #include <rtems/seterr.h>
+#include <pthread.h>
  * @defgroup POSIXAPI RTEMS POSIX API
@@ -125,6 +127,19 @@ RTEMS_INLINE_ROUTINE int _POSIX_Zero_or_minus_one_plus_errno(
   return (type *) the_object
+ * See also The Open Group Base Specifications Issue 7, IEEE Std 1003.1-2008,
+ * 2016 Edition, subsection 2.9.9, Synchronization Object Copies and
+ * Alternative Mappings.
+ * http://pubs.opengroup.org/onlinepubs/9699919799/functions/V2_chap02.html#tag_15_09_09
+RTEMS_INLINE_ROUTINE bool _POSIX_Is_valid_pshared( int pshared )
+  return pshared == PTHREAD_PROCESS_PRIVATE ||
+    pshared == PTHREAD_PROCESS_SHARED;
 #endif
diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
index 08acb539b5..c7161b0daf 100644
--- a/cpukit/posix/src/mutexinit.c
+++ b/cpukit/posix/src/mutexinit.c
@@ -19,6 +19,7 @@
 #endif
+#include <rtems/posix/posixapi.h>
@@ -62,14 +63,9 @@ int pthread_mutex_init(
   if ( !the_attr->is_initialized )
     return EINVAL;
-   *  We only support process private mutexes.
-  if ( the_attr->process_shared == PTHREAD_PROCESS_SHARED )
-    return ENOSYS;
-  if ( the_attr->process_shared != PTHREAD_PROCESS_PRIVATE )
+  if ( !_POSIX_Is_valid_pshared( the_attr->process_shared ) ) {
     return EINVAL;
    *  Determine the discipline of the mutex
diff --git a/testsuites/psxtests/psx05/init.c b/testsuites/psxtests/psx05/init.c
index cde8733bb0..e524d6f96f 100644
--- a/testsuites/psxtests/psx05/init.c
+++ b/testsuites/psxtests/psx05/init.c
@@ -429,10 +429,13 @@ void *POSIX_Init(
   status = pthread_mutexattr_init( &attr );
   rtems_test_assert( !status );
-  puts( "Init: pthread_mutex_init - ENOSYS (process wide scope)" );
-  attr.process_shared = PTHREAD_PROCESS_SHARED;
+  puts( "Init: pthread_mutex_init - process shared scope" );
+  status = pthread_mutexattr_setpshared( &attr, PTHREAD_PROCESS_SHARED );
+  rtems_test_assert( status == 0 );
   status = pthread_mutex_init( &Mutex_id, &attr );
-  rtems_test_assert( status == ENOSYS );
+  status = pthread_mutex_destroy( &Mutex_id );
   puts( "Init: pthread_mutex_init - EINVAL (invalid scope)" );
   attr.process_shared = -1;
diff --git a/testsuites/psxtests/psx05/psx05.scn b/testsuites/psxtests/psx05/psx05.scn
index 4e66ceabf6..0315eee562 100644
--- a/testsuites/psxtests/psx05/psx05.scn
+++ b/testsuites/psxtests/psx05/psx05.scn
@@ -37,7 +37,7 @@ Init: pthread_mutexattr_setprotocol - SUCCESSFUL
 Init: pthread_mutexattr_setprioceiling - SUCCESSFUL
 Init: pthread_mutex_init - EINVAL (bad priority ceiling)
 Init: Resetting mutex attributes
-Init: pthread_mutex_init - ENOSYS (process wide scope)
+Init: pthread_mutex_init - process shared scope
 Init: pthread_mutex_init - EINVAL (invalid type)
2.12.3
