Test suite's minimum sample has no test banners
Wed Sep 20 05:04:24 UTC 2017
On 20/09/17 05:26, Chris Johns wrote:
> The test suite's sample test minimum.exe has no test banners and so it appears
> in the test results as invalid or time out.
> How should we gather a result for this test?
The test documentation in minimum.doc is quite fitting. I guess the
purpose of this test is to see how much code and data is needed to run
one task without drivers and anything else. So, the test output is
probably the ELF file itself.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
