Many BSPs Fail with Debug Enabled
Joel Sherrill
joel at rtems.org
Wed Sep 20 18:24:55 UTC 2017
Thanks for fixing so many. Now it is down to these failures.
These are BSPs where enabling debug resulted in more tests not
fitting. Do we add all of these test build/link failures to the tcfg?
log/arm-lm3s3749.log
log/arm-lpc1768_mbed_ahb_ram_eth.log
log/arm-lpc2362.log
log/arm-lpc23xx_tli800.log
log/arm-lpc24xx_ncs_rom_int.log
log/arm-lpc24xx_plx800_rom_int.log
log/arm-lpc32xx_mzx_stage_1.log
log/arm-rtl22xx_t.log
log/arm-tms570ls3137_hdk_intram.log
log/m68k-mcf52235.log
log/m68k-mcf5225x.log
This is a real build failure:
log/powerpc-t32mppc.log
../../../../../t32mppc/lib/start.o: In function `bsp_exc_vector_base':
/home/joel/rtems-work/rtems-testing/rtems/build-powerpc-t32mppc-rtems/powerpc-rtems4.12/c/t32mppc/lib/libbsp/powerpc/t32mppc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/t32mppc/start/start.S:117:
undefined reference to `ppc_exc_interrupt'
All Raspberry Pi BSP variants built. Not sure what happened
on those before.
--joel
On Wed, Sep 20, 2017 at 9:03 AM, Sebastian Huber <
> On 19/09/17 21:18, Joel Sherrill wrote:
> Hi
>> I am starting to investigate the failures but 41 BSPs fail to
>> build with --enable-rtems-debug and --enable-tests=all.
>> Some fail because tests are too large to fit with debug enabled.
>> These fail with an error related to bsp_interrupt_assert:
>> log/powerpc-mpc8260ads.log
>> log/powerpc-psim.log
>> log/powerpc-qemuppc.log
> I fixed this.
>> These fail with an error about bsp_interrupt_dispatch:
>> log/arm-raspberrypi2.log
>> log/arm-raspberrypi.log
> I didn't get these errors.
> log/powerpc-beatnik.log
>> log/powerpc-brs5l.log
>> log/powerpc-brs6l.log
>> log/powerpc-br_uid.log
>> log/powerpc-dp2.log
>> log/powerpc-haleakala.log
>> log/powerpc-hsc_cm01.log
>> log/powerpc-icecube.log
>> log/powerpc-mcp750.log
>> log/powerpc-mpc8309som.log
>> log/powerpc-mpc8313erdb.log
>> log/powerpc-mpc8349eamds.log
>> log/powerpc-mtx603e.log
>> log/powerpc-mvme2100.log
>> log/powerpc-mvme2307.log
>> log/powerpc-mvme3100.log
>> log/powerpc-mvme5500.log
>> log/powerpc-pghplus.log
>> log/powerpc-pm520_cr825.log
>> log/powerpc-pm520_ze30.log
>> log/powerpc-qemuprep-altivec.log
>> log/powerpc-qemuprep.log
>> log/powerpc-tqm8xx_stk8xx.log
>> log/powerpc-virtex4.log
>> log/powerpc-virtex5.log
>> log/powerpc-virtex.log
> I fixed them except t32mppc. I will have a look at this t
> <https://maps.google.com/?q=ook+at+this+t&entry=gmail&source=g>omorrow.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170920/e4867cdb/attachment.html>
