[PATCH] posix: Implement self-contained POSIX barriers
    Sebastian Huber
    Thu Sep 21 13:29:45 UTC 2017
Update #3114.
 cpukit/libcsupport/include/rtems/libcsupport.h    |   1 -
 cpukit/libcsupport/src/resource_snapshot.c        |   1 -
 cpukit/posix/Makefile.am                          |   3 +-
 cpukit/posix/include/rtems/posix/barrier.h        |  64 -------------
 cpukit/posix/include/rtems/posix/barrierimpl.h    |  87 ++++++++++-------
 cpukit/posix/include/rtems/posix/config.h         |   6 --
 cpukit/posix/preinstall.am                        |   4 -
 cpukit/posix/src/pbarrier.c                       |  51 ----------
 cpukit/posix/src/pbarrierdestroy.c                |  44 +++------
 cpukit/posix/src/pbarrierinit.c                   | 109 +++++++++-------------
 cpukit/posix/src/pbarrierwait.c                   |  58 +++++++-----
 cpukit/rtems/src/rtemsobjectgetapiclassname.c     |   1 -
 cpukit/sapi/include/confdefs.h                    |  25 -----
 cpukit/score/include/rtems/score/objectimpl.h     |   1 -
 cpukit/score/include/rtems/sysinit.h              |   1 -
 testsuites/psxtests/psxbarrier01/main.c           |   2 -
 testsuites/psxtests/psxbarrier01/psxbarrier01.scn |   7 +-
 testsuites/psxtests/psxbarrier01/test.c           |  82 +++++++++++-----
 testsuites/psxtests/psxconfig01/init.c            |  13 ---
 testsuites/psxtmtests/psxtmbarrier01/init.c       |   1 -
 testsuites/psxtmtests/psxtmbarrier02/init.c       |   1 -
 testsuites/psxtmtests/psxtmbarrier03/init.c       |   1 -
 testsuites/psxtmtests/psxtmbarrier04/init.c       |   1 -
 testsuites/sptests/spsysinit01/init.c             |  16 ----
 24 files changed, 208 insertions(+), 372 deletions(-)
 delete mode 100644 cpukit/posix/include/rtems/posix/barrier.h
 delete mode 100644 cpukit/posix/src/pbarrier.c
diff --git a/cpukit/libcsupport/include/rtems/libcsupport.h b/cpukit/libcsupport/include/rtems/libcsupport.h
index e51b250f13..ace61c5c0d 100644
--- a/cpukit/libcsupport/include/rtems/libcsupport.h
+++ b/cpukit/libcsupport/include/rtems/libcsupport.h
@@ -111,7 +111,6 @@ typedef struct {
 } rtems_resource_rtems_api;
 typedef struct {
-  uint32_t active_barriers;
   uint32_t active_condition_variables;
   uint32_t active_message_queues;
   uint32_t active_mutexes;
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 9e026ff222..87d4a0108a 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -69,7 +69,6 @@ static const struct {
   { OBJECTS_CLASSIC_API, OBJECTS_RTEMS_TIMERS }
   #ifdef RTEMS_POSIX_API
-    { OBJECTS_POSIX_API, OBJECTS_POSIX_BARRIERS },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_CONDITION_VARIABLES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_MESSAGE_QUEUES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_MUTEXES },
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 2c88dbbc19..5f76ecc1d4 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -49,7 +49,6 @@ include_rtems_posix_HEADERS += include/rtems/posix/semaphoreimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/threadsup.h
 include_rtems_posix_HEADERS += include/rtems/posix/timer.h
 include_rtems_posix_HEADERS += include/rtems/posix/timerimpl.h
-include_rtems_posix_HEADERS += include/rtems/posix/barrier.h
 include_rtems_posix_HEADERS += include/rtems/posix/barrierimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/rwlock.h
 include_rtems_posix_HEADERS += include/rtems/posix/rwlockimpl.h
@@ -73,7 +72,7 @@ libposix_a_SOURCES +=  src/pthreadatfork.c
 ## BARRIER_C_FILES
 libposix_a_SOURCES += src/barrierattrdestroy.c src/barrierattrgetpshared.c \
-    src/barrierattrinit.c src/barrierattrsetpshared.c src/pbarrier.c \
+    src/barrierattrinit.c src/barrierattrsetpshared.c \
     src/pbarrierdestroy.c src/pbarrierinit.c \
     src/pbarrierwait.c
diff --git a/cpukit/posix/include/rtems/posix/barrier.h b/cpukit/posix/include/rtems/posix/barrier.h
deleted file mode 100644
index e445586511..0000000000
--- a/cpukit/posix/include/rtems/posix/barrier.h
+++ /dev/null
@@ -1,64 +0,0 @@
- * @file
- * @brief Constants and Structures Associated with the POSIX Barrier Manager
- * This include file contains all the constants and structures associated
- * with the POSIX Barrier Manager.
- * Directives provided are:
- *  - create a barrier
- *  - delete a barrier
- *  - wait for a barrier
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_POSIX_BARRIER_H
-#define _RTEMS_POSIX_BARRIER_H
-#include <rtems/score/object.h>
-#include <rtems/score/corebarrier.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup POSIXBarrier POSIX Barriers
- * @ingroup POSIXAPI
- * This encapsulates functionality which implements the RTEMS API
- * Barrier Manager.
- * This type defines the control block used to manage each barrier.
-typedef struct {
-  /** This is used to manage a barrier as an object. */
-  Objects_Control          Object;
-  /** This is used to implement the barrier. */
-  CORE_barrier_Control     Barrier;
-}   POSIX_Barrier_Control;
-#ifdef __cplusplus
-#endif
-#endif
-/*  end of include file */
diff --git a/cpukit/posix/include/rtems/posix/barrierimpl.h b/cpukit/posix/include/rtems/posix/barrierimpl.h
index fae66a6171..9f0588050d 100644
--- a/cpukit/posix/include/rtems/posix/barrierimpl.h
+++ b/cpukit/posix/include/rtems/posix/barrierimpl.h
@@ -11,6 +11,8 @@
+ *  Copyright (c) 2017 embedded brains GmbH
@@ -19,63 +21,76 @@
 #ifndef _RTEMS_POSIX_BARRIERIMPL_H
 #define _RTEMS_POSIX_BARRIERIMPL_H
-#include <rtems/posix/barrier.h>
-#include <rtems/score/corebarrierimpl.h>
-#include <rtems/score/objectimpl.h>
 #include <pthread.h>
+#include <rtems/score/percpu.h>
+#include <rtems/score/threadqimpl.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
- *  The following defines the information control block used to manage
- *  this class of objects.
+#define POSIX_BARRIER_MAGIC 0x1cf03773UL
-extern Objects_Information _POSIX_Barrier_Information;
+#define POSIX_BARRIER_TQ_OPERATIONS &_Thread_queue_Operations_FIFO
- * @brief Allocate a barrier control block.
- * This function allocates a barrier control block from
- * the inactive chain of free barrier control blocks.
-RTEMS_INLINE_ROUTINE POSIX_Barrier_Control *_POSIX_Barrier_Allocate( void )
+typedef struct {
+  unsigned long flags;
+  unsigned int count;
+  unsigned int waiting_threads;
+  Thread_queue_Syslock_queue Queue;
+} POSIX_Barrier_Control;
+static inline POSIX_Barrier_Control *_POSIX_Barrier_Get(
+  pthread_barrier_t *_barrier
-  return (POSIX_Barrier_Control *)
-    _Objects_Allocate( &_POSIX_Barrier_Information );
+  return (POSIX_Barrier_Control *) _barrier;
- * @brief Free a barrier control block.
- * This routine frees a barrier control block to the
- * inactive chain of free barrier control blocks.
-RTEMS_INLINE_ROUTINE void _POSIX_Barrier_Free (
-  POSIX_Barrier_Control *the_barrier
+static inline Thread_Control *_POSIX_Barrier_Queue_acquire(
+  POSIX_Barrier_Control *barrier,
+  Thread_queue_Context  *queue_context
-  _CORE_barrier_Destroy( &the_barrier->Barrier );
-  _Objects_Free( &_POSIX_Barrier_Information, &the_barrier->Object );
+  ISR_Level       level;
+  Thread_Control *executing;
+  _Thread_queue_Context_initialize( queue_context );
+  _Thread_queue_Context_ISR_disable( queue_context, level );
+  _Thread_queue_Context_set_ISR_level( queue_context, level );
+  executing = _Thread_Executing;
+  _Thread_queue_Queue_acquire_critical(
+    &barrier->Queue.Queue,
+    &executing->Potpourri_stats,
+    &queue_context->Lock_context.Lock_context
+  return executing;
-RTEMS_INLINE_ROUTINE POSIX_Barrier_Control *_POSIX_Barrier_Get(
-  const pthread_barrier_t *barrier,
-  Thread_queue_Context    *queue_context
+static inline void _POSIX_Barrier_Queue_release(
-  _Thread_queue_Context_initialize( queue_context );
-  return (POSIX_Barrier_Control *) _Objects_Get(
-    (Objects_Id) *barrier,
-    &queue_context->Lock_context.Lock_context,
-    &_POSIX_Barrier_Information
+  _Thread_queue_Queue_release(
+#define POSIX_BARRIER_VALIDATE_OBJECT( bar ) \
+  do { \
+    if ( \
+      ( bar ) == NULL \
+        || ( (uintptr_t) ( bar ) ^ POSIX_BARRIER_MAGIC ) != ( bar )->_flags \
+      return EINVAL; \
+  } while ( 0 )
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/posix/include/rtems/posix/config.h b/cpukit/posix/include/rtems/posix/config.h
index 6c74216dc2..dc1ef0c2f1 100644
--- a/cpukit/posix/include/rtems/posix/config.h
+++ b/cpukit/posix/include/rtems/posix/config.h
@@ -100,12 +100,6 @@ typedef struct {
    * This field contains the maximum number of POSIX API
-   * barriers which are configured for this application.
-  uint32_t                            maximum_barriers;
-   * This field contains the maximum number of POSIX API
    * read/write locks which are configured for this application.
   uint32_t                            maximum_rwlocks;
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index cfb087c923..c7f071f5fd 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -140,10 +140,6 @@ $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h: include/rtems/posix/timerimpl.h $(PR
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h
-$(PROJECT_INCLUDE)/rtems/posix/barrier.h: include/rtems/posix/barrier.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/barrier.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/barrier.h
 $(PROJECT_INCLUDE)/rtems/posix/barrierimpl.h: include/rtems/posix/barrierimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/barrierimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/barrierimpl.h
diff --git a/cpukit/posix/src/pbarrier.c b/cpukit/posix/src/pbarrier.c
index 8216a080b1..0000000000
--- a/cpukit/posix/src/pbarrier.c
+++ /dev/null
@@ -1,51 +0,0 @@
- *  @file
- *  This file initializes the POSIX Barrier Manager.
- *  COPYRIGHT (c) 1989-2013.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <limits.h>
-#include <rtems/system.h>
-#include <rtems/config.h>
-#include <rtems/sysinit.h>
-#include <rtems/posix/barrierimpl.h>
-Objects_Information _POSIX_Barrier_Information;
- *  @brief _POSIX_Barrier_Manager_initialization
-static void _POSIX_Barrier_Manager_initialization(void)
-  _Objects_Initialize_information(
-    &_POSIX_Barrier_Information,    /* object information table */
-    OBJECTS_POSIX_API,              /* object API */
-    OBJECTS_POSIX_BARRIERS,         /* object class */
-    Configuration_POSIX_API.maximum_barriers,
-				    /* maximum objects of this class */
-    sizeof( POSIX_Barrier_Control ),/* size of this object's control block */
-    true,                           /* true if the name is a string */
-    _POSIX_PATH_MAX,                /* maximum length of each object's name */
-    NULL                            /* Proxy extraction support callout */
-RTEMS_SYSINIT_ITEM(
-  _POSIX_Barrier_Manager_initialization,
-  RTEMS_SYSINIT_POSIX_BARRIER,
-  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/posix/src/pbarrierdestroy.c b/cpukit/posix/src/pbarrierdestroy.c
index 8f85762211..83d06318b5 100644
--- a/cpukit/posix/src/pbarrierdestroy.c
+++ b/cpukit/posix/src/pbarrierdestroy.c
@@ -9,6 +9,8 @@
  *  COPYRIGHT (c) 1989-2007.
@@ -20,47 +22,23 @@
- *  This directive allows a thread to delete a barrier specified by
- *  the barrier id.  The barrier is freed back to the inactive
- *  barrier chain.
- *  @param[in] barrier is the barrier id
- *  @return This method returns 0 if there was not an
- *  error. Otherwise, a status code is returned indicating the
- *  source of the error.
-int pthread_barrier_destroy(
-  pthread_barrier_t *barrier
+int pthread_barrier_destroy( pthread_barrier_t *_barrier )
-  POSIX_Barrier_Control *the_barrier;
+  POSIX_Barrier_Control *barrier;
   Thread_queue_Context   queue_context;
-  if ( barrier == NULL ) {
-    return EINVAL;
-  _Objects_Allocator_lock();
-  the_barrier = _POSIX_Barrier_Get( barrier, &queue_context );
+  POSIX_BARRIER_VALIDATE_OBJECT( _barrier );
-  if ( the_barrier == NULL ) {
-    _Objects_Allocator_unlock();
-    return EINVAL;
+  barrier = _POSIX_Barrier_Get( _barrier );
-  _CORE_barrier_Acquire_critical( &the_barrier->Barrier, &queue_context );
+  _POSIX_Barrier_Queue_acquire( barrier, &queue_context );
-  if ( the_barrier->Barrier.number_of_waiting_threads != 0 ) {
-    _CORE_barrier_Release( &the_barrier->Barrier, &queue_context );
+  if ( barrier->waiting_threads != 0 ) {
+    _POSIX_Barrier_Queue_release( barrier, &queue_context );
     return EBUSY;
-  _Objects_Close( &_POSIX_Barrier_Information, &the_barrier->Object );
-  _POSIX_Barrier_Free( the_barrier );
+  barrier->flags = 0;
   return 0;
diff --git a/cpukit/posix/src/pbarrierinit.c b/cpukit/posix/src/pbarrierinit.c
index c14cc0cb90..7f434c9dcc 100644
--- a/cpukit/posix/src/pbarrierinit.c
+++ b/cpukit/posix/src/pbarrierinit.c
@@ -11,6 +11,8 @@
  *  COPYRIGHT (c) 1989-2006.
@@ -20,28 +22,37 @@
 #include "config.h"
 #endif
-#include <pthread.h>
-#include <errno.h>
 #include <rtems/posix/posixapi.h>
- *  pthread_barrier_init
- *  This directive creates a barrier.  A barrier id is returned.
- *  Input parameters:
- *    barrier          - pointer to barrier id
- *    attr             - barrier attributes
- *    count            - number of threads before automatic release
- *  Output parameters:
- *    barrier     - barrier id
- *    0           - if successful
- *    error code  - if unsuccessful
+RTEMS_STATIC_ASSERT(
+  offsetof( POSIX_Barrier_Control, flags )
+    == offsetof( pthread_barrier_t, _flags ),
+  POSIX_BARRIER_CONTROL_FLAGS
+  offsetof( POSIX_Barrier_Control, count )
+    == offsetof( pthread_barrier_t, _count ),
+  POSIX_BARRIER_CONTROL_COUNT
+  offsetof( POSIX_Barrier_Control, waiting_threads )
+    == offsetof( pthread_barrier_t, _waiting_threads ),
+  POSIX_BARRIER_CONTROL_WAITING_THREADS
+  offsetof( POSIX_Barrier_Control, Queue )
+    == offsetof( pthread_barrier_t, _Queue ),
+  POSIX_BARRIER_CONTROL_QUEUE
+  sizeof( POSIX_Barrier_Control ) == sizeof( pthread_barrier_t ),
+  POSIX_BARRIER_CONTROL_SIZE
 int pthread_barrier_init(
@@ -49,62 +60,34 @@ int pthread_barrier_init(
   unsigned int                 count
-  CORE_barrier_Attributes        the_attributes;
-  pthread_barrierattr_t          my_attr;
-  const pthread_barrierattr_t   *the_attr;
+  struct _Thread_queue_Queue queue = _THREAD_QUEUE_INITIALIZER;
    *  Error check parameters
-  if ( !barrier )
-    return EINVAL;
-  if ( count == 0 )
+  if ( barrier == NULL ) {
     return EINVAL;
-   * If the user passed in NULL, use the default attributes
-  if ( attr ) {
-    the_attr = attr;
-  } else {
-    (void) pthread_barrierattr_init( &my_attr );
-    the_attr = &my_attr;
-   * Now start error checking the attributes that we are going to use
-  if ( !the_attr->is_initialized )
-    return EINVAL;
-  if ( !_POSIX_Is_valid_pshared( the_attr->process_shared ) ) {
+  if ( count == 0 ) {
     return EINVAL;
-   * Convert from POSIX attributes to Core Barrier attributes
-  the_attributes.discipline    = CORE_BARRIER_AUTOMATIC_RELEASE;
-  the_attributes.maximum_count = count;
-  the_barrier = _POSIX_Barrier_Allocate();
+  if ( attr != NULL ) {
+     * Now start error checking the attributes that we are going to use
+    if ( !attr->is_initialized )
+      return EINVAL;
-  if ( !the_barrier ) {
-    return EAGAIN;
+    if ( !_POSIX_Is_valid_pshared( attr->process_shared ) ) {
+      return EINVAL;
-  _CORE_barrier_Initialize( &the_barrier->Barrier, &the_attributes );
-  _Objects_Open_u32(
-    &the_barrier->Object,
-    0
-  *barrier = the_barrier->Object.id;
+  barrier->_flags = (uintptr_t) barrier ^ POSIX_BARRIER_MAGIC;
+  barrier->_count = count;
+  barrier->_waiting_threads = 0;
+  barrier->_Queue = queue;
   return 0;
diff --git a/cpukit/posix/src/pbarrierwait.c b/cpukit/posix/src/pbarrierwait.c
index 117beac553..9719112256 100644
--- a/cpukit/posix/src/pbarrierwait.c
+++ b/cpukit/posix/src/pbarrierwait.c
@@ -9,6 +9,8 @@
@@ -21,32 +23,44 @@
-THREAD_QUEUE_OBJECT_ASSERT( POSIX_Barrier_Control, Barrier.Wait_queue );
-int pthread_barrier_wait(
+int pthread_barrier_wait( pthread_barrier_t *_barrier )
-  Status_Control         status;
-    return EINVAL;
-    return EINVAL;
+  executing = _POSIX_Barrier_Queue_acquire( barrier, &queue_context );
+  waiting_threads = barrier->waiting_threads;
+  ++waiting_threads;
-  _Thread_queue_Context_set_no_timeout( &queue_context );
-  status = _CORE_barrier_Seize(
-    &the_barrier->Barrier,
-    _Thread_Executing,
-    true,
-    &queue_context
-  return _POSIX_Get_error( status );
+  if ( waiting_threads == barrier->count ) {
+    barrier->waiting_threads = 0;
+    _Thread_queue_Flush_critical(
+      POSIX_BARRIER_TQ_OPERATIONS,
+      _Thread_queue_Flush_default_filter,
+      &queue_context
+    return PTHREAD_BARRIER_SERIAL_THREAD;
+  } else {
+    barrier->waiting_threads = waiting_threads;
+    _Thread_queue_Context_set_thread_state(
+      &queue_context,
+      STATES_WAITING_FOR_BARRIER
+    _Thread_queue_Context_set_do_nothing_enqueue_callout( &queue_context );
+    _Thread_queue_Context_set_no_timeout( &queue_context );
+    _Thread_queue_Enqueue(
+      executing,
+      &queue_context
+    return 0;
diff --git a/cpukit/rtems/src/rtemsobjectgetapiclassname.c b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
index 4d3b1cb37c..ecac3a5c5f 100644
--- a/cpukit/rtems/src/rtemsobjectgetapiclassname.c
+++ b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
@@ -53,7 +53,6 @@ static const rtems_assoc_t rtems_object_api_posix_assoc[] = {
   { "Semaphore",               OBJECTS_POSIX_SEMAPHORES, 0},
   { "Condition Variable",      OBJECTS_POSIX_CONDITION_VARIABLES, 0},
   { "Timer",                   OBJECTS_POSIX_TIMERS, 0},
-  { "Barrier",                 OBJECTS_POSIX_BARRIERS, 0},
   { "RWLock",                  OBJECTS_POSIX_RWLOCKS, 0},
   { "Shared Memory",           OBJECTS_POSIX_SHMS, 0},
   { NULL,                      0, 0}
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 5fe366089e..c8bb18ae07 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2081,10 +2081,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \
         rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
     #endif
-    #if !defined(CONFIGURE_MAXIMUM_POSIX_BARRIERS)
-      #define CONFIGURE_MAXIMUM_POSIX_BARRIERS \
-        rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
-    #endif
     #if !defined(CONFIGURE_MAXIMUM_POSIX_RWLOCKS)
       #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS \
@@ -2448,7 +2444,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #include <signal.h>
   #include <limits.h>
   #include <mqueue.h>
-  #include <rtems/posix/barrier.h>
   #include <rtems/posix/cond.h>
   #include <rtems/posix/mqueue.h>
   #include <rtems/posix/mutex.h>
@@ -2573,21 +2568,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
    * This configuration parameter specifies the maximum number of
-   * POSIX API barriers.
-  #ifndef CONFIGURE_MAXIMUM_POSIX_BARRIERS
-    #define CONFIGURE_MAXIMUM_POSIX_BARRIERS 0
-  #endif
-   * This macro is calculated to specify the memory required for
-  #define _CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(_barriers) \
-    _Configure_Object_RAM(_barriers, sizeof(POSIX_Barrier_Control) )
-   * This configuration parameter specifies the maximum number of
    * POSIX API rwlocks.
   #ifndef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
@@ -2842,7 +2822,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
         CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES) + \
       _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \
         CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) + \
-      _CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(CONFIGURE_MAXIMUM_POSIX_BARRIERS) + \
       _CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( \
         CONFIGURE_MAXIMUM_POSIX_RWLOCKS) + \
       _CONFIGURE_MEMORY_FOR_POSIX_SHMS( \
@@ -3296,7 +3275,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS,
       CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES,
       CONFIGURE_MAXIMUM_POSIX_SEMAPHORES,
-      CONFIGURE_MAXIMUM_POSIX_BARRIERS,
       CONFIGURE_MAXIMUM_POSIX_RWLOCKS,
       CONFIGURE_MAXIMUM_POSIX_SHMS,
       CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE,
@@ -3512,7 +3490,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     uint32_t POSIX_QUEUED_SIGNALS;
     uint32_t POSIX_MESSAGE_QUEUES;
     uint32_t POSIX_SEMAPHORES;
-    uint32_t POSIX_BARRIERS;
     uint32_t POSIX_RWLOCKS;
     uint32_t POSIX_SHMS;
 #endif
@@ -3566,7 +3543,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     _CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES(
       CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES ),
     _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ),
-    _CONFIGURE_MEMORY_FOR_POSIX_BARRIERS( CONFIGURE_MAXIMUM_POSIX_BARRIERS ),
     _CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( CONFIGURE_MAXIMUM_POSIX_RWLOCKS ),
     _CONFIGURE_MEMORY_FOR_POSIX_SHMS( CONFIGURE_MAXIMUM_POSIX_SHMS ),
     _CONFIGURE_MEMORY_FOR_POSIX_TIMERS( CONFIGURE_MAXIMUM_POSIX_TIMERS ),
@@ -3638,7 +3614,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
        (CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_SEMAPHORES != 0) || \
-       (CONFIGURE_MAXIMUM_POSIX_BARRIERS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_RWLOCKS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_SHMS != 0) || \
       defined(CONFIGURE_POSIX_INIT_THREAD_TABLE))
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index cd36ce6316..e68035d338 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -91,7 +91,6 @@ typedef enum {
   OBJECTS_POSIX_SEMAPHORES          = 7,
   OBJECTS_POSIX_CONDITION_VARIABLES = 8,
   OBJECTS_POSIX_TIMERS              = 9,
-  OBJECTS_POSIX_BARRIERS            = 10,
   OBJECTS_POSIX_RWLOCKS             = 11,
   OBJECTS_POSIX_SHMS                = 12
 } Objects_POSIX_API;
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index bd4778ab5c..29ad24dc2f 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -52,7 +52,6 @@ extern "C" {
 #define RTEMS_SYSINIT_POSIX_MESSAGE_QUEUE        000364
 #define RTEMS_SYSINIT_POSIX_SEMAPHORE            000365
 #define RTEMS_SYSINIT_POSIX_TIMER                000366
-#define RTEMS_SYSINIT_POSIX_BARRIER              000367
 #define RTEMS_SYSINIT_POSIX_RWLOCK               000368
 #define RTEMS_SYSINIT_POSIX_SHM                  000369
 #define RTEMS_SYSINIT_POSIX_KEYS                 00036a
diff --git a/testsuites/psxtests/psxbarrier01/main.c b/testsuites/psxtests/psxbarrier01/main.c
index 6475016730..f031c05b3c 100644
--- a/testsuites/psxtests/psxbarrier01/main.c
+++ b/testsuites/psxtests/psxbarrier01/main.c
@@ -40,8 +40,6 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 10
-#define CONFIGURE_MAXIMUM_POSIX_BARRIERS 1
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/psxtests/psxbarrier01/psxbarrier01.scn b/testsuites/psxtests/psxbarrier01/psxbarrier01.scn
index d568d8d03e..c7ef3fd245 100644
--- a/testsuites/psxtests/psxbarrier01/psxbarrier01.scn
+++ b/testsuites/psxtests/psxbarrier01/psxbarrier01.scn
@@ -23,14 +23,11 @@ pthread_barrier_init( &barrier, &attr, 1 ) -- EINVAL
 pthread_barrierattr_setpshared( &attr, shared ) -- OK
 pthread_barrier_init( &barrier, &attr, 1 ) -- OK
 pthread_barrier_destroy( &barrier ) -- OK
-pthread_barrier_init( &barrier, NULL, 1 ) -- OK
-pthread_barrier_init( &barrier, NULL, 1 ) -- EAGAIN
-pthread_barrier_destroy( &barrier ) -- OK
 pthread_barrierattr_destroy( &attr ) -- OK
 pthread_barrier_destroy( NULL ) -- EINVAL
-pthread_barrier_destroy( &bad_barrier ) -- EINVAL
+pthread_barrier_destroy( bad_barrier ) -- EINVAL
 pthread_barrier_wait( NULL ) -- EINVAL
-pthread_barrier_wait( &bad_barrier ) -- EINVAL
+pthread_barrier_wait( bad_barrier ) -- EINVAL
 pthread_barrierattr_init( &attr ) -- OK
 pthread_barrier_init( &barrier, &attr, 2 ) -- OK
diff --git a/testsuites/psxtests/psxbarrier01/test.c b/testsuites/psxtests/psxbarrier01/test.c
index 16e8665b94..4253b21057 100644
--- a/testsuites/psxtests/psxbarrier01/test.c
+++ b/testsuites/psxtests/psxbarrier01/test.c
@@ -4,6 +4,8 @@
  *  COPYRIGHT (c) 1989-2009.
@@ -16,6 +18,7 @@
+#include <string.h>
 /* #define __USE_XOPEN2K XXX already defined on GNU/Linux */
@@ -24,6 +27,55 @@
 const char rtems_test_name[] = "PSXBARRIER 1";
+static void test_barrier_null( void )
+  int eno;
+  eno = pthread_barrier_init( NULL, NULL, 1 );
+  rtems_test_assert( eno == EINVAL );
+  eno = pthread_barrier_wait( NULL );
+  eno = pthread_barrier_destroy( NULL );
+static void test_barrier_not_initialized( void )
+  pthread_barrier_t bar;
+  int eno;
+  memset( &bar, 0xff, sizeof( bar ) );
+  eno = pthread_barrier_wait(& bar) ;
+  eno = pthread_barrier_destroy( &bar );
+static void test_barrier_invalid_copy( void )
+  pthread_barrier_t bar2;
+  int eno;
+  eno = pthread_barrier_init( &bar, NULL, 1 );
+  rtems_test_assert( eno == 0 );
+  memcpy( &bar2, &bar, sizeof( bar2 ) );
+  eno = pthread_barrier_wait( &bar2 );
+  eno = pthread_barrier_destroy( &bar2 );
 #define NUMBER_THREADS 2
 pthread_t ThreadIds[NUMBER_THREADS];
 pthread_barrier_t Barrier;
@@ -57,7 +109,7 @@ int main(
 #endif
-  pthread_barrier_t     bad_barrier = 100;
+  pthread_barrier_t    *bad_barrier = NULL;
   pthread_barrier_t     barrier;
   pthread_barrierattr_t attr;
   int                   status;
@@ -178,20 +230,6 @@ int main(
   status = pthread_barrier_destroy( &barrier );
   rtems_test_assert( status == 0 );
-  /* allocating too many */
-  puts( "pthread_barrier_init( &barrier, NULL, 1 ) -- OK" );
-  status = pthread_barrier_init( &barrier, NULL, 1 );
-  rtems_test_assert( status == 0 );
-  puts( "pthread_barrier_init( &barrier, NULL, 1 ) -- EAGAIN" );
-  rtems_test_assert( status == EAGAIN );
-  /* clean up */
-  puts( "pthread_barrier_destroy( &barrier ) -- OK" );
-  status = pthread_barrier_destroy( &barrier );
   puts( "pthread_barrierattr_destroy( &attr ) -- OK" );
   status = pthread_barrierattr_destroy( &attr );
@@ -202,8 +240,8 @@ int main(
   status = pthread_barrier_destroy( NULL );
   rtems_test_assert( status == EINVAL );
-  puts( "pthread_barrier_destroy( &bad_barrier ) -- EINVAL" );
-  status = pthread_barrier_destroy( &bad_barrier );
+  puts( "pthread_barrier_destroy( bad_barrier ) -- EINVAL" );
+  status = pthread_barrier_destroy( bad_barrier );
   /*************** pthread_barrier_wait ERROR CHECKs *********/
@@ -212,8 +250,8 @@ int main(
   status = pthread_barrier_wait( NULL );
-  puts( "pthread_barrier_wait( &bad_barrier ) -- EINVAL" );
-  status = pthread_barrier_wait( &bad_barrier );
+  puts( "pthread_barrier_wait( bad_barrier ) -- EINVAL" );
+  status = pthread_barrier_wait( bad_barrier );
   /*************** ACTUALLY CREATE ONE CHECK *****************/
@@ -224,7 +262,6 @@ int main(
   puts( "pthread_barrier_init( &barrier, &attr, 2 ) -- OK" );
   status = pthread_barrier_init( &barrier, &attr, 2 );
-  rtems_test_assert( barrier != 0 );
@@ -234,7 +271,6 @@ int main(
   puts( "pthread_barrier_init( &Barrier, &attr, NUMBER_THREADS ) -- OK" );
   status = pthread_barrier_init( &Barrier, &attr, NUMBER_THREADS );
   for (i=0 ; i<NUMBER_THREADS ; i++ ) {
@@ -253,6 +289,10 @@ int main(
     sleep(1);
+  test_barrier_null();
+  test_barrier_not_initialized();
+  test_barrier_invalid_copy();
   /*************** END OF TEST *****************/
   TEST_END();
   exit(0);
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index dd741c11cb..c9e6bfd9fb 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -60,7 +60,6 @@ const char rtems_test_name[] = "PSXCONFIG 1";
 #define CONFIGURE_MAXIMUM_TIMERS 59
 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 17
-#define CONFIGURE_MAXIMUM_POSIX_BARRIERS 31
 #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 29
 #define POSIX_MQ_COUNT 5
 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 19
@@ -431,18 +430,6 @@ static rtems_task Init(rtems_task_argument argument)
 #endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
-  for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_BARRIERS; ++i) {
-    pthread_barrier_t barrier;
-    eno = pthread_barrier_init(&barrier, NULL, 1);
-    rtems_test_assert(eno == 0);
-  rtems_resource_snapshot_take(&snapshot);
-    snapshot.posix_api.active_barriers == CONFIGURE_MAXIMUM_POSIX_BARRIERS
-#endif
 #ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
   for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES; ++i) {
     pthread_cond_t cond;
diff --git a/testsuites/psxtmtests/psxtmbarrier01/init.c b/testsuites/psxtmtests/psxtmbarrier01/init.c
index 690653fe64..7caa6727d0 100644
--- a/testsuites/psxtmtests/psxtmbarrier01/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier01/init.c
@@ -91,7 +91,6 @@ void *POSIX_Init(
 #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
 #define CONFIGURE_POSIX_INIT_THREAD_TABLE
diff --git a/testsuites/psxtmtests/psxtmbarrier02/init.c b/testsuites/psxtmtests/psxtmbarrier02/init.c
index 0506db9874..6705125ac6 100644
--- a/testsuites/psxtmtests/psxtmbarrier02/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier02/init.c
@@ -133,7 +133,6 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS     OPERATION_COUNT + 2
diff --git a/testsuites/psxtmtests/psxtmbarrier03/init.c b/testsuites/psxtmtests/psxtmbarrier03/init.c
index d81be082be..27feac1fe8 100644
--- a/testsuites/psxtmtests/psxtmbarrier03/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier03/init.c
@@ -98,7 +98,6 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS     2
diff --git a/testsuites/psxtmtests/psxtmbarrier04/init.c b/testsuites/psxtmtests/psxtmbarrier04/init.c
index 2fc3b76fac..baf1bf1032 100644
--- a/testsuites/psxtmtests/psxtmbarrier04/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier04/init.c
@@ -90,7 +90,6 @@ void *POSIX_Init(
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index 612ba145a2..ff450b9ace 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -114,8 +114,6 @@ typedef enum {
   POSIX_SEMAPHORE_POST,
   POSIX_TIMER_PRE,
   POSIX_TIMER_POST,
-  POSIX_BARRIER_PRE,
-  POSIX_BARRIER_POST,
   POSIX_RWLOCK_PRE,
   POSIX_RWLOCK_POST,
   POSIX_SHM_PRE,
@@ -505,18 +503,6 @@ LAST(RTEMS_SYSINIT_POSIX_TIMER)
   next_step(POSIX_TIMER_POST);
-FIRST(RTEMS_SYSINIT_POSIX_BARRIER)
-  assert(_POSIX_Barrier_Information.maximum == 0);
-  next_step(POSIX_BARRIER_PRE);
-LAST(RTEMS_SYSINIT_POSIX_BARRIER)
-  assert(_POSIX_Barrier_Information.maximum != 0);
-  next_step(POSIX_BARRIER_POST);
 FIRST(RTEMS_SYSINIT_POSIX_RWLOCK)
   assert(_POSIX_RWLock_Information.maximum == 0);
@@ -757,8 +743,6 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 1
2.12.3
