Test suite's minimum sample has no test banners
Joel Sherrill
joel at rtems.org
Thu Sep 21 15:24:06 UTC 2017
On Thu, Sep 21, 2017 at 2:27 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 20/09/2017 15:08, Chris Johns wrote:
> > Is it worth running? I am wondering about hard coding a filter to not
> run it in
> > rtems-test runs.
> I have add test failure exceptions and minimum is the only hard coded
> entry. If
> this test runs and does not time out it is marked as a pass.
The intent of this test is to demonstrate the smallest executable and
data size possible.
Looking at the sizes on a few BSPs this morning, I wonder why it is
so large:
text data bss dec hex filename
45792 880 3088 49760 c260 erc32/.../minimum.exe
49344 888 6896 57128 df28 jmr3904/.../minimum.exe
66000 1220 16709968 16777188 ffffe4 psim/.../minimum.exe
76832 1008 268341188 268419028 fffbfd4
xilinx_zynq_a9_qemu/.../minimum.exe
Any ideas where the large .text size is coming from?
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170921/858c074e/attachment.html>
