Test suite's minimum sample has no test banners
Thu Sep 21 07:27:21 UTC 2017
On 20/09/2017 15:08, Chris Johns wrote:
> Is it worth running? I am wondering about hard coding a filter to not run it in
> rtems-test runs.
I have add test failure exceptions and minimum is the only hard coded entry. If
this test runs and does not time out it is marked as a pass.
