On 20/09/2017 15:08, Chris Johns wrote: > > Is it worth running? I am wondering about hard coding a filter to not run it in > rtems-test runs. > I have add test failure exceptions and minimum is the only hard coded entry. If this test runs and does not time out it is marked as a pass. Chris
