Improve coverage analysis toolset
Cillian O'Donnell
cpodonnell8 at gmail.com
Mon Apr 2 16:10:35 UTC 2018
Sure if you want to crack at it.
If you pull the ini-update branch again, I've included the other files
you'll need.
Now if you try and run rtems-test with coverage you will get
cpod at cpod ~ $ $HOME/development/rtems/test/rtems-tools/tester/rtems-test
--rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
--rtems-bsp=leon3_qemu --coverage
--rtems-builddir=$HOME/development/rtems/leon3
sparc-rtems5/c/leon3/testsuites/samples
RTEMS Testing - Tester, 5 (80a1e6d9607e)
Traceback (most recent call last):
File "/home/cpod/development/rtems/test/rtems-tools/tester/rtems-test",
line 40, in <module>
rt.test.run()
File "/home/cpod/development/rtems/test/rtems-tools/tester/rt/test.py",
line 310, in run
coverage = coverage_get_obj(opts, path_to_builddir[1])
line 230, in coverage_get_obj
coverage_obj = coverage.coverage_run(opts.defaults, path_to_builddir)
File "/home/cpod/development/rtems/test/rtems-tools/tester/rt/coverage.py",
line 329, in __init__
self.config_map = self.macros.macros['coverage']
KeyError: 'coverage'
So this is the starting point
https://github.com/cillianodonnell/rtems-tools/
blob/coverage-merge/tester/rt/coverage.py#L329
The coverage options from here
https://github.com/cillianodonnell/rtems-tools/blob/ini-update/tester/rtems/
testing/coverage.ini
which was once
testing/coverage.mc
So you'll have to dig down from coverage.py to see what needs tob e changed
to parse the new format.
Good luck.
On 2 April 2018 at 16:22, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Hello ,
> I'm currently going through the coverage code , Can you please help me
> understand what are the specific changes that are needed for the coverage
> to be running again?
> thanks
> -- vijay
> On 26 March 2018 at 09:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> 1. Yes , I plan to work on identifying the discrepancies between what
>> covoar reports directly and what the gcov reports based on its gcov output.
>> 2. I understand this point that the scripting that generates symbol set
>> file, needs to be modified accordingly
>> 3. I have planned to make a note and understand the requirements, changes
>> needed and the desired type of output during the community bonding period,
>> so that I have a clear picture of the objective before I start working on
>> it.
>> The plan is to work on gcov after the existing work is merged.
>> Have I planned too much to work on during the summer? Should I modify my
>> plan in some way? Please suggest .
>> Thanks
>> -- vijay
>> On 26 March 2018 at 03:49, Joel Sherrill <joel at rtems.org> wrote:
>>> Just a couple of questions and planning issues. The planning issues
>>> are because the requirements for some of the work are likely not solid
>>> on our side.
>>> 1. Do you plan to work on identifying the discrepancies between
>>> what covoar reports directly and what gcov reports based on its
>>> gcov file output? I ask because I lined up someone from the GCC
>>> community who should be able to tell us what is not right once
>>> we have specific cases.
>>> 2. My recollection is that the symbol set file is generated from
>>> the RTEMS libraries under test. The scripting that generates this
>>> file will have to change also. The set of symbols changes as
>>> RTEMS evolves.
>>> 3. Chris has had ideas on changing the output from directly
>>> producing ascii and html to something else. It is on he and I
>>> to give you input on the actual format.
>>> Personally getting all existing work merged and it in a state
>>> where we can produce coverage reports again is really a
>>> critical thing. The previous work changed it from being
>>> a standalone shell script that drove things to part of the RSB
>>> and make it possible to have the reports based on subdirectories
>>> rather than one large report.
>>> I don't 'think this changes your plan except that the plan seems to
>>> put gcov as bonus work. It isn't discussed as work during the
>>> summer.It would be nice to get gcov correctness done earlier
>>> because that might be the best way to nice reports. For
>>> example, running lcov on the .gcov files produced by covoar
>>> might be an option.
>>> --joel
>>> On Sun, Mar 25, 2018 at 3:16 PM, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> submitted !
>>>> If you find time , please give final review as well.
>>>> Thanks
>>>> On 26 Mar 2018 1:44 a.m., "Joel Sherrill" <joel at rtems.org> wrote:
>>>>> I am out and not at a computer. Someone can double check me but I
>>>>> believe you can replace the PDF you upload.
>>>>> Unless someone answers soon, just upload it.
>>>>> --joel
>>>>> On Mar 25, 2018 2:37 PM, "Vijay Kumar Banerjee" <
>>>>>> It's the last day before the deadline!
>>>>>> Please provide a final review of the proposal before submitting.
>>>>>> Thanks
>>>>>> -- vijay
>>>>>> On 24 March 2018 at 21:37, Vijay Kumar Banerjee <
>>>>>>> hello mentors and other developers of the community , there are only
>>>>>>> three days remaining to the GSoC proposal submission deadline.
>>>>>>> I request the mentors and everyone in the community who has
>>>>>>> experience in RTEMS, to please go through my proposal for Coverage Analysis
>>>>>>> tool improvement project , if they have time , and suggest any kind of
>>>>>>> improvements and changes .
>>>>>>> here is the link to the proposal
>>>>>>> https://docs.google.com/document/d/1UjCWE1ojrpDQLQ2fQqxHU0SC
>>>>>>> rLETlerxD6t0SOcQNLQ/edit?usp=sharing
>>>>>>> Thank you
>>>>>>> -- vijay
>>>>>>> On 22 March 2018 at 04:30, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>> Glad you have tests running. Hopefully as Cillian suggested, you
>>>>>>>> can fix the
>>>>>>>> remaining issues to see coverage.
>>>>>>>> We certainly need to get this merged if Chris is OK with it and it
>>>>>>>> doesn't
>>>>>>>> break anything else.
>>>>>>>> I am reviewing proposals now. Seems to be a queue. :)
>>>>>>>> --joel
>>>>>>>> On Wed, Mar 21, 2018 at 4:42 AM, Vijay Kumar Banerjee <
>>>>>>>>> Sir ,
>>>>>>>>> I have done the changes in the proposal , based on the comments in
>>>>>>>>> the google doc , please review it and suggest any further changes if
>>>>>>>>> required
>>>>>>>>> Thank you ,
>>>>>>>>> -- vijay
>>>>>>>>> P.S : the previous version is in parentheses , I will remove them
>>>>>>>>> after you review the changes .
>>>>>>>>> On 18 March 2018 at 16:05, Vijay Kumar Banerjee <
>>>>>>>>>> Thanks Cillian :)
>>>>>>>>>> It's great to see it running , I'll do some background reading
>>>>>>>>>> about RSB, and RTEMS-Tools along with the covoar code . And also work on my
>>>>>>>>>> python skills.
>>>>>>>>>> to try rtems-test on a bsp that runs gdb , I tried it on erc32
>>>>>>>>>> and that also worked.
>>>>>>>>>> I'm also waiting for Joel and other mentors' review on my draft
>>>>>>>>>> proposal, so that I can also work on it and make any changes if needed.
>>>>>>>>>> Thanks .
>>>>>>>>>> -- vijay
>>>>>>>>>> On 18 March 2018 at 14:17, Cillian O'Donnell <
>>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>>> On 18 March 2018 at 06:47, Vijay Kumar Banerjee <
>>>>>>>>>>>> It worked !
>>>>>>>>>>> That's great! That's the good news then. I was using an old
>>>>>>>>>>> leon3 build and maybe some older Qemu too and I think that's why I didn't
>>>>>>>>>>> see any issues initially. I was hoping you could see the coverage running
>>>>>>>>>>> and the reports generated from that but it looks like the full update to
>>>>>>>>>>> the current master will be necessary to have a look. So until the parsing
>>>>>>>>>>> for the INI files is added to the coverage.py we won't see the coverage
>>>>>>>>>>> running. Unfortunately, I'm in the middle of exams until the following
>>>>>>>>>>> Monday so I won't be able to sink any more time into it until then. You can
>>>>>>>>>>> still figure out the RSB problem you're having and do some background
>>>>>>>>>>> reading, brush up on your Python skills, have a read of the covoar code
>>>>>>>>>>> https://github.com/RTEMS/rtems-tools/blob/master/tester/covo
>>>>>>>>>>> ar/covoar.cc
>>>>>>>>>>> just skim through, read the comments, get a sense of the what
>>>>>>>>>>> it's doing and in what order.
>>>>>>>>>>>> It's great to see it running ! I have attached the result .
>>>>>>>>>>>> -- vijay
>>>>>>>>>>>> On 18 March 2018 at 02:31, Cillian O'Donnell <
>>>>>>>>>>>>> On 17 March 2018 at 20:08, Vijay Kumar Banerjee <
>>>>>>>>>>>>>> yes it prints hello world
>>>>>>>>>>>>> Alright I've added an .ini for leon3-qemu to the current
>>>>>>>>>>>>> rtems-tools. Pull this branch
>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>>>>> and try
>>>>>>>>>>>>> --log=coverage-analysis.log --rtems-bsp=leon3_qemu
>>>>>>>>>>>>> $HOME/development/rtems/leon3/sparc-rtems5/c/leon3/testsuite
>>>>>>>>>>>>> s/samples
>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>> On 18 March 2018 at 01:31, Cillian O'Donnell <
>>>>>>>>>>>>>>> If you run just one test by itself without rtems-test
>>>>>>>>>>>>>>> qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>>>>>>>>>>> -nographic -M leon3_generic -kernel $HOME/development/rtems/leon3/
>>>>>>>>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>>>>>>>>>>>>>> Does the hello world print out?
>>>>>>>>>>>>>>> On 17 March 2018 at 14:46, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>> I built it manually
>>>>>>>>>>>>>>>> the environment variable PATH looks like this
>>>>>>>>>>>>>>>> /home/lunatic/qemu/install/bin
>>>>>>>>>>>>>>>> :/home/lunatic/development/rte
>>>>>>>>>>>>>>>> ms/5/bin:/usr/local/bin:/usr/l
>>>>>>>>>>>>>>>> ocal/sbin:/usr/bin:/usr/sbin:/
>>>>>>>>>>>>>>>> home/lunatic/.local/bin:/home/lunatic/bin
>>>>>>>>>>>>>>>> I tried to run rtems-test again without --coverage , it
>>>>>>>>>>>>>>>> gives the same result
>>>>>>>>>>>>>>>> I have attached the log.
>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>> On 17 March 2018 at 00:55, Cillian O'Donnell <
>>>>>>>>>>>>>>>>> Yes this is something more than my build, I'll need
>>>>>>>>>>>>>>>>> someone a bit more expert in the RSB to step in there. In the meantime,
>>>>>>>>>>>>>>>>> lets just build couverture-qemu manually so we can see is everything else
>>>>>>>>>>>>>>>>> working.
>>>>>>>>>>>>>>>>> git clone https://github.com/AdaCore/qemu
>>>>>>>>>>>>>>>>> cd qemu
>>>>>>>>>>>>>>>>> ./configure --target-list=sparc-softmmu
>>>>>>>>>>>>>>>>> --prefix=$HOME/qemu/install --disable-docs --disable-virtfs --disable-werror
>>>>>>>>>>>>>>>>> make
>>>>>>>>>>>>>>>>> make install
>>>>>>>>>>>>>>>>> then add the prefix to $PATH in .bashrc as well like
>>>>>>>>>>>>>>>>> before.
>>>>>>>>>>>>>>>>> export PATH=$HOME/qemu/install/bin:$PATH
>>>>>>>>>>>>>>>>> Then run rtem-test and see what happens
>>>>>>>>>>>>>>>>> On 16 March 2018 at 19:13, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>> the same error comes when I try to build qemu from the
>>>>>>>>>>>>>>>>>> RTEMS/rtems-source-builder as well
>>>>>>>>>>>>>>>>>> is the issue coming from my system ? I'm using fedora 27
>>>>>>>>>>>>>>>>>> 64bit
>>>>>>>>>>>>>>>>>> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
>>>>>>>>>>>>>>>>>>> yes , the same thing happens
>>>>>>>>>>>>>>>>>>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <
>>>>>>>>>>>>>>>>>>>> If you build regular qemu with the RSB, does the same
>>>>>>>>>>>>>>>>>>>> thing happen?
>>>>>>>>>>>>>>>>>>>> Try
>>>>>>>>>>>>>>>>>>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>>>>>>>>>>>>>>>>>>> --prefix=$HOME/development/5 devel/qemu
>>>>>>>>>>>>>>>>>>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>> still the same error
>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>> Just checked and the build was failing because one of
>>>>>>>>>>>>>>>>>>>>>> the patches needed its hash to be updated to sha256. Just pushed that
>>>>>>>>>>>>>>>>>>>>>> change. The build finishes successfully on my end. Pull that change into
>>>>>>>>>>>>>>>>>>>>>> couverture-build branch and try it again. I'm not seeing any automake stuff
>>>>>>>>>>>>>>>>>>>>>> here, so just check that and let me know.
>>>>>>>>>>>>>>>>>>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>>>>>>>>>>>>>>>>>>> onnell/rtems-source-builder/tree/couverture-build )
>>>>>>>>>>>>>>>>>>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1
>>>>>>>>>>>>>>>>>>>>>>> I have attached the error report .
>>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>>>> It runs with a bunch of errors . I have attached
>>>>>>>>>>>>>>>>>>>>>>>>> the log file
>>>>>>>>>>>>>>>>>>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu
>>>>>>>>>>>>>>>>>>>>>>>> (special version of qemu designed for generating extra trace data for
>>>>>>>>>>>>>>>>>>>>>>>> coverage analysis). That's what those errors are about. I have an RSB build
>>>>>>>>>>>>>>>>>>>>>>>> for that.
>>>>>>>>>>>>>>>>>>>>>>>> and the instructions for building it are
>>>>>>>>>>>>>>>>>>>>>>>> https://devel.rtems.org/wiki/G
>>>>>>>>>>>>>>>>>>>>>>>> SoC/2017/coveragetools#Buildin
>>>>>>>>>>>>>>>>>>>>>>>> gCouverture-QemuwiththeRSB
>>>>>>>>>>>>>>>>>>>>>>>> I know what the other problem is too. I have a
>>>>>>>>>>>>>>>>>>>>>>>> specific environment variable defined for the path, sorry I can't even
>>>>>>>>>>>>>>>>>>>>>>>> remember putting it there, I thought that was automatically generated
>>>>>>>>>>>>>>>>>>>>>>>> (probably should be, another thing to add to the list :)... ). So wherever
>>>>>>>>>>>>>>>>>>>>>>>> you stuck the export path for where the rsb built the tools, in .bashrc or
>>>>>>>>>>>>>>>>>>>>>>>> whatever you're using. Also put something like:
>>>>>>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>>>>> /bin:$PATH
>>>>>>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/t
>>>>>>>>>>>>>>>>>>>>>>>> est/rtems-tools/build/tester/covoar:$PATH
>>>>>>>>>>>>>>>>>>>>>>>> or you could just copy covoar into the /bin
>>>>>>>>>>>>>>>>>>>>>>>> directory with all the other rsb tools gcc and all that, it'll find it
>>>>>>>>>>>>>>>>>>>>>>>> either way.
>>>>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>>>>> Looks good. If you run the samples without
>>>>>>>>>>>>>>>>>>>>>>>>>> coverage is everything ok?
>>>>>>>>>>>>>>>>>>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>>>>>>>>>>>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>>>>>>>>>> Do the tests run?
>>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>>>>>> I have attached the output of the ls of that
>>>>>>>>>>>>>>>>>>>>>>>>>>> directory
>>>>>>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee
>>>>>>>>>>>>>>>>>>>>>>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> hello ,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> as told by Joel , I started this thread to
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> further discuss the coverage analysis toolset .
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Current status is , I'm trying to builld and
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> run rtems-test from the coverage-merge branch of the previous GSoC student
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cillian .
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> nell/rtems-tools/tree/coverage-merge
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> "Covoar not found !"
>>>>>>>>>>>>>>>>>>>>>>>>>>>> It's supposed to find it in
>>>>>>>>>>>>>>>>>>>>>>>>>>>> rtems-tools/build/tester/covoar/ If it's in
>>>>>>>>>>>>>>>>>>>>>>>>>>>> there it should be fine. Can you show me the contents of that directory?
>>>>>>>>>>>>>>>>>>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>>>>>>>>>>>>>>>>>>> $ ls
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> the Covoar appeared in
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> rtems-tools/tester/covoar .
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ______________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180402/f7c02960/attachment-0001.html>
