error while running rtems-test with coverage
Wed Apr 4 05:46:52 UTC 2018
On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
> after pulling the ini-update branch from
> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
Any local changes?
> I tried running the rtems-test with the following command
> $HOME/development/rtems/rtems-tools/tester/rtems-test
> --rtems-tools=$HOME/development/rtems/5 --log=coverage_analysis.log
> --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/development/rtems/kernel/leon3
> sparc-rtems5/c/leon3/testsuites/samples
> was getting the KeyError for 'coverage'
Please paste the command and output as it appears in the terminal?
> current status :
> the same command gives the error :
> "mandatory item not found in bsp section : bsp,"
> to make sure I didn't break something , I also tried running from a freshly
> downloaded directory as well, it gives the same error.
Did you try running the following command from the top of the source tree:
 $ grep -r "mandatory item not found" *
