[PATCH v2 1/2] waf: Support building from libbsd.py directly from waf.
Wed Apr 4 07:36:14 UTC 2018
On 04/04/2018 17:14, Christian Mauderer wrote:
> Am 04.04.2018 um 09:00 schrieb Chris Johns:
>> On 04/04/2018 16:35, Christian Mauderer wrote:
>>> Am 04.04.2018 um 08:20 schrieb Chris Johns:
>>>> On 04/04/2018 15:51, Christian Mauderer wrote:
>>>>> Am 04.04.2018 um 07:28 schrieb Chris Johns:
>>>>>> On 04/04/2018 00:43, Christian Mauderer wrote:
>>> Normally I would go for build speed due to the fact that we most likely
>>> build much more often than touching the build system. On the other hand
>>> the build system is already quite hard to understand. So another
>>> alternative could be interesting: Set only one config (and not all) as
>>> default so that for most cases only this one is build.
>> Agreed.
> Was that an agree to the preference of build speed over complexity or
> was it an agree to defaulting to one config?
Defaulting to one config.
