[PATCH v2 1/2] waf: Support building from libbsd.py directly from waf.
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Apr 4 07:38:47 UTC 2018
Am 04.04.2018 um 09:36 schrieb Chris Johns:
> On 04/04/2018 17:14, Christian Mauderer wrote:
>> Am 04.04.2018 um 09:00 schrieb Chris Johns:
>>> On 04/04/2018 16:35, Christian Mauderer wrote:
>>>> Am 04.04.2018 um 08:20 schrieb Chris Johns:
>>>>> On 04/04/2018 15:51, Christian Mauderer wrote:
>>>>>> Am 04.04.2018 um 07:28 schrieb Chris Johns:
>>>>>>> On 04/04/2018 00:43, Christian Mauderer wrote:
>>>> Normally I would go for build speed due to the fact that we most likely
>>>> build much more often than touching the build system. On the other hand
>>>> the build system is already quite hard to understand. So another
>>>> alternative could be interesting: Set only one config (and not all) as
>>>> default so that for most cases only this one is build.
>>> Agreed.
>> Was that an agree to the preference of build speed over complexity or
>> was it an agree to defaulting to one config?
> Defaulting to one config.
OK. Then I'll go for the solution that builds every file for every
config (like done for the BSPs - I just checked that with
beagleboneblack and -white) and default to one config so that the normal
user doesn't see a difference to the current state.
Best regards
Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
