(should have been v2 libbsd: Make modules configurable via ini files.)
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Apr 9 13:58:28 UTC 2018
Sorry, missed the subject line in git send-email. This description is to
the v2-patch-set for the libbsd waf changes.
Am 09.04.2018 um 15:53 schrieb Christian Mauderer:
> Hello,
> this version now contains some changes like discussed with Chris Johns:
> - I moved the fragment composers to builder.py. With that the
>   freebsd_to_rtems dependency to waf_libbsd is removed again.
> - The ini files have now a section "modules" instead of
>   "modules-enabled". The modules are now switched "on" and "off"
>   (instead of 1 and 0).
> - README.waf now contains a note about the default case.
> Beneath that I had a problem with a second configure call using cached
> values from a .lock-waf_linux2_build file. Therefore I changed how and
> when the builders are generated in wscript.
> Again: Any feedback is welcome.
> With kind regards
> Christian Mauderer
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
