(should have been v2 libbsd: Make modules configurable via ini files.)
Tue Apr 10 00:07:41 UTC 2018
On 09/04/2018 23:58, Christian Mauderer wrote:
> Sorry, missed the subject line in git send-email. This description is to
> the v2-patch-set for the libbsd waf changes.
> Am 09.04.2018 um 15:53 schrieb Christian Mauderer:
>> Hello,
>> this version now contains some changes like discussed with Chris Johns:
>> - I moved the fragment composers to builder.py. With that the
>>   freebsd_to_rtems dependency to waf_libbsd is removed again.
>> - The ini files have now a section "modules" instead of
>>   "modules-enabled". The modules are now switched "on" and "off"
>>   (instead of 1 and 0).
>> - README.waf now contains a note about the default case.
Looks good.
A minor thing, in wscript can we remove '#import libbsd_waf'?
>> Beneath that I had a problem with a second configure call using cached
>> values from a .lock-waf_linux2_build file. Therefore I changed how and
>> when the builders are generated in wscript.
I agree with the comments and I do not have a better solution. I may ask Thomas
(irc: ita) to review and provide some feedback once in the repo.
>> Again: Any feedback is welcome.
Please push when ready.
Thank you for this work.
