(should have been v2 libbsd: Make modules configurable via ini files.)
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Apr 10 07:09:33 UTC 2018
Am 10.04.2018 um 02:07 schrieb Chris Johns:
> On 09/04/2018 23:58, Christian Mauderer wrote:
>> Sorry, missed the subject line in git send-email. This description is to
>> the v2-patch-set for the libbsd waf changes.
>> Am 09.04.2018 um 15:53 schrieb Christian Mauderer:
>>> Hello,
>>> this version now contains some changes like discussed with Chris Johns:
>>> - I moved the fragment composers to builder.py. With that the
>>>   freebsd_to_rtems dependency to waf_libbsd is removed again.
>>> - The ini files have now a section "modules" instead of
>>>   "modules-enabled". The modules are now switched "on" and "off"
>>>   (instead of 1 and 0).
>>> - README.waf now contains a note about the default case.
> Looks good.
> A minor thing, in wscript can we remove '#import libbsd_waf'?
>>> Beneath that I had a problem with a second configure call using cached
>>> values from a .lock-waf_linux2_build file. Therefore I changed how and
>>> when the builders are generated in wscript.
> I agree with the comments and I do not have a better solution. I may ask Thomas
> (irc: ita) to review and provide some feedback once in the repo.
>>> Again: Any feedback is welcome.
> Please push when ready.
> Thank you for this work.
> Chris
Hello Chris,
thanks for your review. I removed that commented line and pushed the
patches.
Best regards
Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
