[PATCH] setting raw in get_items
vijaykumar9597 at gmail.com vijaykumar9597 at gmail.com
Tue Apr 10 21:04:02 UTC 2018
 rtemstoolkit/configuration.py | 4 ++--
 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/rtemstoolkit/configuration.py b/rtemstoolkit/configuration.py
index 10d97e5..53ad79b 100644
--- a/rtemstoolkit/configuration.py
+++ b/rtemstoolkit/configuration.py
@@ -98,7 +98,7 @@ class configuration:
     def get_items(self, section, err = True, flatten = True):
         try:
             items = []
-            for name, key in self.config.items(section):
+            for name, key in self.config.items(section,raw=True):
                 if flatten:
                     items += [(name, key.replace(os.linesep, ' '))]
                 else:
@@ -117,7 +117,7 @@ class configuration:
     def get_item_names(self, section, err = True):
         try:
-            return [item[0] for item in self.config.items(section)]
+            return [item[0] for item in self.config.items(section,raw=True)]
         except:
             if err:
                 raise error.general('config: section "%s" not found' % (section))
2.14.3
