[PATCH] initial
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Apr 11 03:57:18 UTC 2018
yes I'm using python 3
On Wed, 11 Apr 2018, 04:49 Chris Johns, <chrisj at rtems.org> wrote:
> Hi,
> Are you using Python 3?
> This is an upstream package ...
> https://github.com/msoulier/tftpy/blob/master/tftpy/TftpServer.py
> and it looks to me like this has been fixed upstream so we should pull
> down what
> is there are update our versions.
> Chris
> On 11/04/2018 07:04, vijaykumar9597 at gmail.com wrote:
> > From: thelunatic <vijaykumar9597 at gmail.com>
> > tester/rt/tftpy/TftpServer.py | 4 ++--
> > tester/rt/tftpy/TftpStates.py | 2 +-
> > 2 files changed, 3 insertions(+), 3 deletions(-)
> > diff --git a/tester/rt/tftpy/TftpServer.py
> b/tester/rt/tftpy/TftpServer.py
> > index 07c2107..b6d0ada 100644
> > --- a/tester/rt/tftpy/TftpServer.py
> > +++ b/tester/rt/tftpy/TftpServer.py
> > @@ -53,8 +53,8 @@ class TftpServer(TftpSession):
> > for name in 'dyn_file_func', 'upload_open':
> > attr = getattr(self, name)
> > if attr and not callable(attr):
> > - raise TftpException, "%s supplied, but it is not
> callable." % (
> > - name,)
> > + raise TftpException( "%s supplied, but it is not
> callable." % (
> > + name))
> > if os.path.exists(self.root):
> > log.debug("tftproot %s does exist", self.root)
> > if not os.path.isdir(self.root):
> > diff --git a/tester/rt/tftpy/TftpStates.py
> b/tester/rt/tftpy/TftpStates.py
> > index 801e970..3c147a5 100644
> > --- a/tester/rt/tftpy/TftpStates.py
> > +++ b/tester/rt/tftpy/TftpStates.py
> > @@ -368,7 +368,7 @@ class TftpStateServerRecvWRQ(TftpServerState):
> > f = self.context.upload_open(path, self.context)
> > if f is None:
> > self.sendError(TftpErrors.AccessViolation)
> > - raise TftpException, "Dynamic path %s not permitted" %
> path
> > + raise TftpException("Dynamic path %s not permitted" )%
> path
> > else:
> > self.context.fileobj = f
> > else:
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180411/08caa13c/attachment-0001.html>
