[PATCH] initial
Tue Apr 10 23:19:35 UTC 2018
Hi,
Are you using Python 3?
This is an upstream package ...
 https://github.com/msoulier/tftpy/blob/master/tftpy/TftpServer.py
and it looks to me like this has been fixed upstream so we should pull down what
is there are update our versions.
On 11/04/2018 07:04, vijaykumar9597 at gmail.com wrote:
> From: thelunatic <vijaykumar9597 at gmail.com>
>  tester/rt/tftpy/TftpServer.py | 4 ++--
>  tester/rt/tftpy/TftpStates.py | 2 +-
>  2 files changed, 3 insertions(+), 3 deletions(-)
> diff --git a/tester/rt/tftpy/TftpServer.py b/tester/rt/tftpy/TftpServer.py
> index 07c2107..b6d0ada 100644
> --- a/tester/rt/tftpy/TftpServer.py
> +++ b/tester/rt/tftpy/TftpServer.py
> @@ -53,8 +53,8 @@ class TftpServer(TftpSession):
>          for name in 'dyn_file_func', 'upload_open':
>              attr = getattr(self, name)
>              if attr and not callable(attr):
> -                raise TftpException, "%s supplied, but it is not callable." % (
> -                    name,)
> +                raise TftpException( "%s supplied, but it is not callable." % (
> +                    name))
>          if os.path.exists(self.root):
>              log.debug("tftproot %s does exist", self.root)
>              if not os.path.isdir(self.root):
> diff --git a/tester/rt/tftpy/TftpStates.py b/tester/rt/tftpy/TftpStates.py
> index 801e970..3c147a5 100644
> --- a/tester/rt/tftpy/TftpStates.py
> +++ b/tester/rt/tftpy/TftpStates.py
> @@ -368,7 +368,7 @@ class TftpStateServerRecvWRQ(TftpServerState):
>              f = self.context.upload_open(path, self.context)
>              if f is None:
>                  self.sendError(TftpErrors.AccessViolation)
> -                raise TftpException, "Dynamic path %s not permitted" % path
> +                raise TftpException("Dynamic path %s not permitted" )% path
>              else:
>                  self.context.fileobj = f
>          else:
