Bug in rtems-tester?
Joel Sherrill
joel at rtems.org
Wed Apr 11 22:31:19 UTC 2018
On Wed, Apr 11, 2018 at 3:42 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 12/04/2018 00:39, Joel Sherrill wrote:
> > Hi
> > These failures have persisted across all the autoconf changes:
> > Failures:
> > powerpc/qemuprep-altivec:
> > configure --target=powerpc-rtems5 --enable-rtemsbsp=qemuprep-
> altivec\
> > --prefix=/home/joel/rtems-work/bsps --enable-networking
> --enable-smp
> > ld/collect2:0 error: no error message found!
> altivec\
> > --prefix=/home/joel/rtems-work/bsps --enable-debug --enable-smp
> altivec\
> > --prefix=/home/joel/rtems-work/bsps --enable-debug --enable-\
> > networking --enable-smp
> altivec\
> > --prefix=/home/joel/rtems-work/bsps --enable-smp
> > I checked and it looks like qemuprep-altivec is listed in the smp
> excludes section.
> Yes that does look like a bug.
> The second bug is the rather average error message.
> > It is the only BSP with a - in the name that is in smp-excludes. Could
> it be
> > that the matching fails in this case?
> > The other is pc586-sse which is SMP excluded also but using a different
> mechanism..
> Could you please raise a ticket?
Done.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180411/8bf382d9/attachment.html>
