error while running rtems-test with coverage
Cillian O'Donnell
cpodonnell8 at gmail.com
Fri Apr 13 16:49:38 UTC 2018
Yeah that's fine but can you just paste the contents here anyway. I'm not
near a laptop and I can't remember which branch your starting from.
On Fri, 13 Apr 2018, 13:51 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> I haven't made any local changes to qemu.cfg
> -- vijay
> On 13 April 2018 at 11:43, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> No that's the right one. I think it might be something to do with
>> qemu.cfg in rtems-tools then. What's in your qemu.cfg? It's in
>> rtems-tools/tester/rtems/testing
>> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> I manually built qemu from here
>>> https://github.com/AdaCore/qemu
>>> I guess this is regular qemu , please send a link for couverture
>>> qemu for manual build.
>>> -- vijay
>>> On 12 April 2018 at 22:23, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Ah that's good progress, those .cov files are supposed to be generated
>>>> by couverture-qemu as the test are run. They contain the trace data. Are
>>>> you definitely running couverture-qemu and not regular qemu?
>>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>>>> I got the parsing of the coverage from the ini file running , now I'm
>>>>> getting the following error and warnings .
>>>>> Running covoar for score
>>>>> WARNING: Unable to read coverage file
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/capture/capture.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/fileio/fileio.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/iostream/cxx_iostream.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/loopback/loopback.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/minimum/minimum.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/nsecs/nsecs.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/paranoia/paranoia.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/pppd/pppd.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/ticker/ticker.exe.cov
>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe.cov
>>>>> ERROR: No information to analyze
>>>>> ***Cleaning tempfiles***
>>>>> error: covoar failure exit code: 1
>>>>> -- vijay
>>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>>> I managed to get the tests running with the following two patches .
>>>>>> Please review them .
>>>>>> -- vijay
>>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>>> I tried to solve the empty get in the way shown in the patch , but
>>>>>>>> it doesn't seems to work, I'm getting the following error now
>>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>>> Traceback (most recent call last):
>>>>>>>> File
>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test", line 40,
>>>>>>>> in <module>
>>>>>>>> rt.test.run()
>>>>>>>> File
>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 303,
>>>>>>>> in run
>>>>>>>> bsp = config.load(bsp[1], opts)
>>>>>>>> File
>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py", line
>>>>>>>> 461, in load
>>>>>>>> return opts.defaults['bsp']
>>>>>>>> File
>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py", line
>>>>>>>> 190, in __getitem__
>>>>>>>> raise IndexError('key: %s' % (key))
>>>>>>>> IndexError: key: bsp
>>>>>>>> I still Couldn't figure out why it's happening, when I use
>>>>>>> RawConfigParse , it seems to run nicely though .
>>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>>> -- vijay
>>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>>> I got the rtems-test running
>>>>>>>>>> I found that get_item_names(section, err) in configuration.py
>>>>>>>>>> was returning an empty list to the
>>>>>>>>>> item_names in load(bsp,opts) for config.py this was giving out
>>>>>>>>>> the error mandatory item not found .
>>>>>>>>>> I have attached the patch file .
>>>>>>>>>> current status :
>>>>>>>>>> rtems-test is running without coverage
>>>>>>>>>> running coverage gives the following error :
>>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>> File
>>>>>>>>>> in <module>
>>>>>>>>>> rt.test.run()
>>>>>>>>>> File
>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 310,
>>>>>>>>>> in run
>>>>>>>>>> coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>>>>>>> File
>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 230,
>>>>>>>>>> in coverage_get_obj
>>>>>>>>>> coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>>> path_to_builddir)
>>>>>>>>>> File
>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py", line
>>>>>>>>>> 335, in __init__
>>>>>>>>>> self.report_format = self.config_map['report_format'][2]
>>>>>>>>> This is back to the difference in cfg formats. It's looking for
>>>>>>>>> the last line here
>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>>> Which is now
>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>>>> It's trying to grab the 'html' text so it can trigger the right
>>>>>>>>> section of code in coverage.py
>>>>>>>>> It's something just to tell which format we want the report to
>>>>>>>>> output
>>>>>>>> Understood , I'll come to that after I manage to get the test
>>>>>>>> running first .
>>>>>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>>>>>>> Thanks
>>>>>>>>>> -- vijay
>>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>>> > https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>>> Any local changes?
>>>>>>>>>>> > I tried running the rtems-test with the following command
>>>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>> --log=coverage_analysis.log
>>>>>>>>>>> > --rtems-bsp=leon3_qemu
>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>>> Please paste the command and output as it appears in the
>>>>>>>>>>> terminal?
>>>>>>>>>>> > current status :
>>>>>>>>>>> > the same command gives the error :
>>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>>> > to make sure I didn't break something , I also tried running
>>>>>>>>>>> from a freshly
>>>>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>>>>> Did you try running the following command from the top of the
>>>>>>>>>>> source tree:
>>>>>>>>>>> $ grep -r "mandatory item not found" *
>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/a13e5043/attachment-0001.html>
