error while running rtems-test with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Apr 13 17:18:07 UTC 2018
sure
# RTEMS Tools Project (http://www.rtems.org/)
# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
# All rights reserved.
# This file is part of the RTEMS Tools package in 'rtems-tools'.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are
met:
# 1. Redistributions of source code must retain the above copyright notice,
# this list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright
notice,
# this list of conditions and the following disclaimer in the documentation
# and/or other materials provided with the distribution.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
# POSSIBILITY OF SUCH DAMAGE.
# QEMU
# Use a qemu command to run the executable in the qemu simulator.
%include %{_configdir}/base.cfg
%include %{_configdir}/checks.cfg
# Console.
%define console_stdio
%include %{_configdir}/console.cfg
# RTEMS version
%include %{_rtdir}/rtems/version.cfg
# Qemu common option patterns.
#%define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
-nographic
%define qemu_opts_base -no-reboot -monitor null -serial stdio -nographic
%define qemu_opts_no_net -net none
# Qemu executable
%ifn %{defined bsp_qemu_opts}
%define bsp_qemu_opts %{nil}
%endif
%define qemu_cmd qemu-system-%{bsp_arch}
%define qemu_opts %{bsp_qemu_opts}
# Executable
%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
-- vijay
On 13 April 2018 at 22:19, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Yeah that's fine but can you just paste the contents here anyway. I'm not
> near a laptop and I can't remember which branch your starting from.
> On Fri, 13 Apr 2018, 13:51 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> I haven't made any local changes to qemu.cfg
>> -- vijay
>> On 13 April 2018 at 11:43, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> No that's the right one. I think it might be something to do with
>>> qemu.cfg in rtems-tools then. What's in your qemu.cfg? It's in
>>> rtems-tools/tester/rtems/testing
>>> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> I manually built qemu from here
>>>> https://github.com/AdaCore/qemu
>>>> I guess this is regular qemu , please send a link for couverture
>>>> qemu for manual build.
>>>> -- vijay
>>>> On 12 April 2018 at 22:23, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> Ah that's good progress, those .cov files are supposed to be generated
>>>>> by couverture-qemu as the test are run. They contain the trace data. Are
>>>>> you definitely running couverture-qemu and not regular qemu?
>>>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>>>>> I got the parsing of the coverage from the ini file running , now I'm
>>>>>> getting the following error and warnings .
>>>>>> Running covoar for score
>>>>>> WARNING: Unable to read coverage file /home/lunatic/development/
>>>>>> rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/
>>>>>> samples/base_sp/base_sp.exe.cov
>>>>>> samples/capture/capture.exe.cov
>>>>>> samples/cdtest/cdtest.exe.cov
>>>>>> samples/fileio/fileio.exe.cov
>>>>>> samples/hello/hello.exe.cov
>>>>>> samples/iostream/cxx_iostream.exe.cov
>>>>>> samples/loopback/loopback.exe.cov
>>>>>> samples/minimum/minimum.exe.cov
>>>>>> samples/nsecs/nsecs.exe.cov
>>>>>> samples/paranoia/paranoia.exe.cov
>>>>>> samples/pppd/pppd.exe.cov
>>>>>> samples/ticker/ticker.exe.cov
>>>>>> samples/unlimited/unlimited.exe.cov
>>>>>> ERROR: No information to analyze
>>>>>> ***Cleaning tempfiles***
>>>>>> error: covoar failure exit code: 1
>>>>>> -- vijay
>>>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>>>> I managed to get the tests running with the following two patches .
>>>>>>> Please review them .
>>>>>>> -- vijay
>>>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>>>> I tried to solve the empty get in the way shown in the patch , but
>>>>>>>>> it doesn't seems to work, I'm getting the following error now
>>>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>>>> Traceback (most recent call last):
>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
>>>>>>>>> line 40, in <module>
>>>>>>>>> rt.test.run()
>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
>>>>>>>>> line 303, in run
>>>>>>>>> bsp = config.load(bsp[1], opts)
>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py",
>>>>>>>>> line 461, in load
>>>>>>>>> return opts.defaults['bsp']
>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py",
>>>>>>>>> line 190, in __getitem__
>>>>>>>>> raise IndexError('key: %s' % (key))
>>>>>>>>> IndexError: key: bsp
>>>>>>>>> I still Couldn't figure out why it's happening, when I use
>>>>>>>> RawConfigParse , it seems to run nicely though .
>>>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>>>> -- vijay
>>>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>>>> I got the rtems-test running
>>>>>>>>>>> I found that get_item_names(section, err) in configuration.py
>>>>>>>>>>> was returning an empty list to the
>>>>>>>>>>> item_names in load(bsp,opts) for config.py this was giving out
>>>>>>>>>>> the error mandatory item not found .
>>>>>>>>>>> I have attached the patch file .
>>>>>>>>>>> current status :
>>>>>>>>>>> rtems-test is running without coverage
>>>>>>>>>>> running coverage gives the following error :
>>>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>>> rt.test.run()
>>>>>>>>>>> line 310, in run
>>>>>>>>>>> coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>>>>>>>> line 230, in coverage_get_obj
>>>>>>>>>>> coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>>>> path_to_builddir)
>>>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py",
>>>>>>>>>>> line 335, in __init__
>>>>>>>>>>> self.report_format = self.config_map['report_format'][2]
>>>>>>>>>> This is back to the difference in cfg formats. It's looking for
>>>>>>>>>> the last line here
>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/
>>>>>>>>>> blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>>>> Which is now
>>>>>>>>>> blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>>>>> It's trying to grab the 'html' text so it can trigger the right
>>>>>>>>>> section of code in coverage.py
>>>>>>>>>> It's something just to tell which format we want the report to
>>>>>>>>>> output
>>>>>>>>> Understood , I'll come to that after I manage to get the test
>>>>>>>>> running first .
>>>>>>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>>>>>>>> Thanks
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>>>> tree/ini-update
>>>>>>>>>>>> Any local changes?
>>>>>>>>>>>> > I tried running the rtems-test with the following command
>>>>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>> --log=coverage_analysis.log
>>>>>>>>>>>> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
>>>>>>>>>>>> development/rtems/kernel/leon3
>>>>>>>>>>>> > sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>>>> Please paste the command and output as it appears in the
>>>>>>>>>>>> terminal?
>>>>>>>>>>>> > current status :
>>>>>>>>>>>> > the same command gives the error :
>>>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>>>> > to make sure I didn't break something , I also tried running
>>>>>>>>>>>> from a freshly
>>>>>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>>>>>> Did you try running the following command from the top of the
>>>>>>>>>>>> source tree:
>>>>>>>>>>>> $ grep -r "mandatory item not found" *
>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/8ef51a16/attachment-0001.html>
