error while running rtems-test with coverage
Cillian O'Donnell
cpodonnell8 at gmail.com
Sun Apr 15 08:32:10 UTC 2018
On 15 April 2018 at 06:46, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 15 April 2018 at 01:45, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> Switch one of these lines out in qemu.cfg.
>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
>> #%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>> -nographic
>> %define qemu_opts_base -no-reboot -monitor null -serial stdio -nographic
>> Just comment out the one that's being used and uncomment one of the
>> others. It should cause a complaint when the tests are run and the qemu cmd
>> should show up in the log so we can take a look at it.
> error: qemu.cfg:71: execute failed: qemu-system-sparc -no-reboot -monitor
> null -serial stdio -nographic -no-reboot -monitor null -serial stdio
> -nographic -M leon3_generic -kernel /home/lunatic/development/
> rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/
> samples/unlimited/unlimited.exe: exit-code:1
> run: qemu-system-sparc -no-reboot -monitor null -serial stdio -nographic
> -no-reboot -mo nitor null -serial stdio -nographic -M leon3_generic
> -kernel /home/lunatic/development/rtem s/kernel/leon3/sparc-rtems5/c/
> leon3/testsuites/samples/unlimited/unlimited.exe -exec-trace
> /home/lunatic/development/rtems/kernel/leon3/sparc-
> rtems5/c/leon3/testsuites/samples/unlimi ted/unlimited.exe.cov
Are those line breaks actually there or is it from the copy and paste.
Like unlimi ted. If so that's definitely the problem. What does your
last section in qemu.cfg look like now? The execute section.
>> On 14 April 2018 at 20:37, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> -- vijay
>>> On 15 April 2018 at 00:50, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 14 April 2018 at 16:42, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org> wrote:
>>>>>> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>>>>>>> Getting this error now seems like something is missing.
>>>>>>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>>>>>>> Coverage environment prepared
>>>>>>> Traceback (most recent call last):
>>>>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test",
>>>>>>> line 40, in <module>
>>>>>>> rt.test.run()
>>>>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py",
>>>>>>> line 353, in run
>>>>>>> tst.reraise()
>>>>>>> line 160, in reraise
>>>>>>> _test_reraise(*self.result)
>>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>> The reraise logic was moved to the rtemstoolkit last year:
>>>>>> https://git.rtems.org/rtems-tools/commit/?id=fa81491764861e6
>>>>>> 3785a3faa241c488469087209
>>>>>> It had some issues that have been fixed and it is being reused else
>>>>>> where in the tester.
>>>>>>> -- vijay
>>>>>>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <
>>>>>>> vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>>>>>>> On 13 April 2018 at 23:51, Cillian O'Donnell <
>>>>>>> <mailto:cpodonnell8 at gmail.com>> wrote:
>>>>>>> Hmmm it's not there. Even so I can almost guarantee you, the
>>>>>>> reason it's not running is that coverage_supported variable
>>>>>>> is
>>>>>>> not being found as true in qemu.cfg and so the the command to
>>>>>>> generated the trace files isn't run and there's no .cov
>>>>>>> files in
>>>>>>> the end. So that's what you'll have to dig into.
>>>>>>> Okay , I'll set it to global then.
>>>>>> Changes need to be on the latest version of master before I will
>>>>>> review them. The failure above indicate the code you have is not up to date.
>>>>> Yes that was the plan. Just to check Vijay your starting point was
>>>>> using the ini-update branch from here?
>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>> That branch is current rtems-tools master that I started to add things
>>>>> back in. The only reraise in there is the one improrted from rtemstoolkit.
>>>> yes this is the branch I'm using , I checked the reraise error , not
>>>> sure how it showed up buit I called it from the reraise module , and
>>>> it got fixed . now I'm stuck here
>>>> error: config error: qemu.cfg:36: No 'target' defined
>>> okay , fixed that .
>>> still getting the warnings of the unable to read .cov
>>>> are we supposed to set the bsp to global as well ?
>>>>>> The change you have made is generating an exception in the tester
>>>>>> thread. If you want to continue down this path you will need to fix what
>>>>>> ever you have added.
>>>>>> The tests are run as threads separate from the main thread so the
>>>>>> exception is caught and re-raised in the main thread letting you know. This
>>>>>> is broken in the old code base you are using.
>>>>>> Why not investigate the reason as indicated and sort if out what the
>>>>>> new format configuration file needs?
>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180415/dd2563d7/attachment-0001.html>
