[PATCH] 5: Use a specific RTEMS tools version
Sebastian Huber
Tue Apr 17 08:21:39 UTC 2018
Download via HTTPS RTEMS file server.
Close 3241.
rtems/config/tools/rtems-tools-5-1.cfg | 28 ++++++++++++++++++++++++++--
1 file changed, 26 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-5-1.cfg b/rtems/config/tools/rtems-tools-5-1.cfg
index 6efc4e3..e0178f0 100644
--- a/rtems/config/tools/rtems-tools-5-1.cfg
+++ b/rtems/config/tools/rtems-tools-5-1.cfg
@@ -7,9 +7,33 @@
%if %{rsb_released}
%define rtems_tools_version %{rsb_version}
+%else
+ %define rtems_tools_version ec419a05ee52869a7d5b8712ea8e7a7d74fde096
%endif
-# The RTEMS Tools build instructions. We use tools 1.
+# Optionally enable/disable building the RTEMS Tools via the command line.
-%include tools/rtems-tools-1.cfg
+%if %{defined with_rtems_tools}
+ %define rtems_tools_build 1
+%endif
+%if %{defined without_rtems_tools}
+ %define rtems_tools_build 0
+%endif
+# Build by default.
+%if ! %{defined rtems_tools_build}
+%endif
+%if %{rtems_tools_build}
+ %source set rtems-tools https://ftp.rtems.org/pub/rtems/people/sebh/rtems-tools-%{rtems_tools_version}.tar.bz2
+ %hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 af1cda88144583bd9471056291d0a19e8ace0e45efded01e7d32014919a8e57e8a47a58497b2c9201dff925316a8b9cfd0d0e6000f4755471fdf5468b5daa517
+ # The RTEMS Tools build instructions.
+ %include tools/rtems-tools-common-1.cfg
+%endif
2.12.3
