[PATCH] 5: Use a specific RTEMS tools version
Joel Sherrill
joel at rtems.org
Wed Apr 18 00:48:57 UTC 2018
On Tue, Apr 17, 2018, 7:27 PM Chris Johns <chrisj at rtems.org> wrote:
> On 17/04/2018 21:18, Sebastian Huber wrote:
> > On 17/04/18 12:12, Chris Johns wrote:
> >> On 17/4/18 6:49 pm, Sebastian Huber wrote:
> >>> On 17/04/18 10:30, Chris Johns wrote:
> >>>> On 17/04/2018 18:21, Sebastian Huber wrote:
> >>>>> Download via HTTPS RTEMS file server.
> >>>>> Close 3241.
> >>>> Can you please explain why this solves the issue in the ticket? I do
> not see
> >>>> how
> >>>> they relate.
> >>> This solves the ticket since git is no longer involved.
> >>>> There can be issues with a sequence of git commands if you are
> switching
> >>>> branches. This can be resolved by improving the sequence used.
> >>>>> rtems/config/tools/rtems-tools-5-1.cfg | 28
> >>>>> 1 file changed, 26 insertions(+), 2 deletions(-)
> >>>>> diff --git a/rtems/config/tools/rtems-tools-5-1.cfg
> >>>>> b/rtems/config/tools/rtems-tools-5-1.cfg
> >>>>> index 6efc4e3..e0178f0 100644
> >>>>> --- a/rtems/config/tools/rtems-tools-5-1.cfg
> >>>>> +++ b/rtems/config/tools/rtems-tools-5-1.cfg
> >>>>> @@ -7,9 +7,33 @@
> >>>>> %if %{rsb_released}
> >>>>> %define rtems_tools_version %{rsb_version}
> >>>>> +%else
> >>>>> + %define rtems_tools_version
> ec419a05ee52869a7d5b8712ea8e7a7d74fde096
> >>>>> %endif
> >>>> Sorry, this is not the right place for this sort of detail. Version
> details
> >>>> need
> >>>> to be in the release defaults or overridden in a an arch specific
> file.
> >>> Sorry, I didn't understand the logic for the rtems_tools_version
> definition at
> >>> all. Why is it dependent on rsb_released?
> >> If the RSB is released the RTEMS ftp server is used for downloads and
> the
> >> version is the RTEMS release verson. The RTEMS tools do not have a
> separate
> >> release cycle from RTEMS and use the same version numbers.
> >>>> Why this version?
> >>> It is the latest commit. So, just the thing that would have been
> picked by the
> >>> current RSB.
> >>> The use of a random HEAD is a major problem from my point of view. It
> makes the
> >>> RSB outcome build time dependent and irreproducible.
> >> Releases are matched. I do not follow how this resolves any dependence
> issue
> >> that may appear such as the dl06 and rtems-ld.
> > For the latest test suite you need an up to date rtems-ld. If you built
> the
> > tools with RSB 703532cb04c6990fb21e97cb7347a16e9df11108 two months ago,
> then it
> > will not work. If you build with RSB
> > today, then everything is fine. This is a serious defect from my point
> of view.
> How is this any different from all the newlib changes you made? To me it
> is the
> same.
+1
Newlib, GCC and binutils bumps have broken things in the past and will
continue to do so. This is a development master and things have to break
periodically.
The next newlib bump picks up at least two corrections to pthread.h which
will break builds. When we update, I will.have to push my changes
correcting the prootoypes in our source.
Plus I have on my to do list to move what I think are the last three POSIX
.h files to newlib. That also is a hard break when newlib bumps.
> Lets not get to too tangled up here it is development. I clearly stated in
> the
> cover email a tools update was needed and in future I will send a single
> specific email to the list to say an update is needed.
> >>>> I do not follow or understand the purpose of the change and with a
> lack of
> >>>> specific detail it appears to solve a local problem. It may appear to
> solve the
> >>>> problem because it side steps an issue related to switching branches.
> >>> There are some reports on the mailing list related to the rtems-tools
> download
> >>> via git. It has at least two problems:
> >>> 1. It fails sporadically.
> >> The real issue in the way git is being sequenced should be fix.
> >>> 2. You need internet access during the build.
> >> If you updated RTEMS and have disconnected and not updated the RSB with
> a new
> >> hash version downloaded from your home ftp area you have stuffed anyway.
> > You should be able to
> > ../source-builder/sb-set-builder --dry-run --with-download ...
> > and then disconnect from the internet to build the tools.
> The ability to create an archive directory is something I would welcome. I
> side
> step around it in the release scripts at the moment but this functionality
> should be moved into the RBS. It will happen when I find the time.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180418/7c132e4d/attachment.html>
