[PATCH 25/40] bsps: Move shared btimer support to bsps
Thu Apr 19 13:26:50 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
 .../timercpucounter.c => bsps/shared/dev/btimer/btimer-cpucounter.c     | 0
 .../libbsp/shared/timerstub.c => bsps/shared/dev/btimer/btimer-stub.c   | 0
 c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am                       | 2 +-
 c/src/lib/libbsp/arm/atsam/Makefile.am                                  | 2 +-
 c/src/lib/libbsp/arm/beagle/Makefile.am                                 | 2 +-
 c/src/lib/libbsp/arm/gdbarmsim/Makefile.am                              | 2 +-
 c/src/lib/libbsp/arm/imx/Makefile.am                                    | 2 +-
 c/src/lib/libbsp/arm/lm3s69xx/Makefile.am                               | 2 +-
 c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am                        | 2 +-
 c/src/lib/libbsp/arm/stm32f4/Makefile.am                                | 2 +-
 c/src/lib/libbsp/arm/tms570/Makefile.am                                 | 2 +-
 c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am                            | 2 +-
 c/src/lib/libbsp/mips/malta/Makefile.am                                 | 2 +-
 c/src/lib/libbsp/moxie/moxiesim/Makefile.am                             | 2 +-
 c/src/lib/libbsp/powerpc/t32mppc/Makefile.am                            | 2 +-
 c/src/lib/libbsp/sh/shsim/Makefile.am                                   | 2 +-
 c/src/lib/libbsp/sparc64/niagara/Makefile.am                            | 2 +-
 c/src/lib/libbsp/sparc64/usiii/Makefile.am                              | 2 +-
 c/src/lib/libbsp/v850/gdbv850sim/Makefile.am                            | 2 +-
 19 files changed, 17 insertions(+), 17 deletions(-)
 rename c/src/lib/libbsp/shared/timercpucounter.c => bsps/shared/dev/btimer/btimer-cpucounter.c (100%)
 rename c/src/lib/libbsp/shared/timerstub.c => bsps/shared/dev/btimer/btimer-stub.c (100%)
diff --git a/c/src/lib/libbsp/shared/timercpucounter.c b/bsps/shared/dev/btimer/btimer-cpucounter.c
similarity index 100%
rename from c/src/lib/libbsp/shared/timercpucounter.c
rename to bsps/shared/dev/btimer/btimer-cpucounter.c
diff --git a/c/src/lib/libbsp/shared/timerstub.c b/bsps/shared/dev/btimer/btimer-stub.c
rename from c/src/lib/libbsp/shared/timerstub.c
rename to bsps/shared/dev/btimer/btimer-stub.c
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
index b7625af8c9..8afedb85f4 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
@@ -82,7 +82,7 @@ librtemsbsp_a_SOURCES += hwlib/src/hwmgr/alt_reset_manager.c
 librtemsbsp_a_SOURCES += ../../shared/getentropy-cpucounter.c
 librtemsbsp_a_SOURCES += ../../shared/cpucounterdiff.c
 librtemsbsp_a_SOURCES += ../../shared/sbrk.c
-librtemsbsp_a_SOURCES += ../../shared/timerstub.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bsp-fdt.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/stackalloc.c
 librtemsbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
diff --git a/c/src/lib/libbsp/arm/atsam/Makefile.am b/c/src/lib/libbsp/arm/atsam/Makefile.am
index a8db8b77a5..ef9809e9fc 100644
--- a/c/src/lib/libbsp/arm/atsam/Makefile.am
+++ b/c/src/lib/libbsp/arm/atsam/Makefile.am
@@ -122,7 +122,7 @@ librtemsbsp_a_SOURCES += ../shared/armv7m/clock/armv7m-clock-config.c
 librtemsbsp_a_SOURCES += clock/systick-freq.c
 # Timer
 # Cache
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-v7m.c
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 7d3167f34d..d9923d1248 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -45,7 +45,7 @@ librtemsbsp_a_SOURCES += ../../shared/sbrk.c
 librtemsbsp_a_SOURCES += ../../shared/gpio.c
 librtemsbsp_a_SOURCES += ../../shared/cpucounterread.c
 librtemsbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
index cb1de3e0d5..faaff8b387 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
+++ b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
@@ -33,7 +33,7 @@ librtemsbsp_a_SOURCES += console/console-io.c
 # clock
 librtemsbsp_a_SOURCES += ../../shared/clock_driver_simidle.c
 # timer
 # start hooks
 librtemsbsp_a_SOURCES += startup/bspstarthooks.c
diff --git a/c/src/lib/libbsp/arm/imx/Makefile.am b/c/src/lib/libbsp/arm/imx/Makefile.am
index 6bf4584814..90fe54c062 100644
--- a/c/src/lib/libbsp/arm/imx/Makefile.am
+++ b/c/src/lib/libbsp/arm/imx/Makefile.am
@@ -34,7 +34,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-defa
diff --git a/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am b/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
index 700ff5f23a..a6bc270fb5 100644
--- a/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
@@ -63,7 +63,7 @@ librtemsbsp_a_SOURCES += console/uart.c
 # Timer
 # Cache
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/cache/nocache.c
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
index 7ed5d22555..5a79cefe8e 100644
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
@@ -42,7 +42,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-default.c
diff --git a/c/src/lib/libbsp/arm/stm32f4/Makefile.am b/c/src/lib/libbsp/arm/stm32f4/Makefile.am
index 00950c02b8..cb69f4e640 100644
--- a/c/src/lib/libbsp/arm/stm32f4/Makefile.am
+++ b/c/src/lib/libbsp/arm/stm32f4/Makefile.am
@@ -67,7 +67,7 @@ librtemsbsp_a_SOURCES += i2c/i2c-config.c
 # Timer
 # Cache
diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
index e188dbf4f2..ff5db2a6c4 100644
--- a/c/src/lib/libbsp/arm/tms570/Makefile.am
+++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
@@ -75,7 +75,7 @@ librtemsbsp_a_SOURCES += clock/clock.c
 librtemsbsp_a_SOURCES += pinmux/pinmux.c
 # Benchmark Timer
-librtemsbsp_a_SOURCES += ../../shared/timercpucounter.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-cpucounter.c
 # Misc
 librtemsbsp_a_SOURCES += misc/cpucounterread.c
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index b557a0a35f..5a7c4ab0d7 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -40,7 +40,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
diff --git a/c/src/lib/libbsp/mips/malta/Makefile.am b/c/src/lib/libbsp/mips/malta/Makefile.am
index b53baf3bdb..8eaa876949 100644
--- a/c/src/lib/libbsp/mips/malta/Makefile.am
+++ b/c/src/lib/libbsp/mips/malta/Makefile.am
@@ -44,7 +44,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console
 librtemsbsp_a_SOURCES += console/conscfg.c
 librtemsbsp_a_SOURCES += console/printk_support.c
 # timer
 librtemsbsp_a_SOURCES += ../../../../../../bsps/mips/shared/irq/installisrentries.c
diff --git a/c/src/lib/libbsp/moxie/moxiesim/Makefile.am b/c/src/lib/libbsp/moxie/moxiesim/Makefile.am
index 950f69da27..28970aae3b 100644
--- a/c/src/lib/libbsp/moxie/moxiesim/Makefile.am
+++ b/c/src/lib/libbsp/moxie/moxiesim/Makefile.am
@@ -34,7 +34,7 @@ librtemsbsp_a_SOURCES += ../../shared/console-polled.c
 librtemsbsp_a_SOURCES += console/syscalls.S
 # timer
 # Cache
diff --git a/c/src/lib/libbsp/powerpc/t32mppc/Makefile.am b/c/src/lib/libbsp/powerpc/t32mppc/Makefile.am
index 73c627a831..4f4d851b75 100644
--- a/c/src/lib/libbsp/powerpc/t32mppc/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/t32mppc/Makefile.am
@@ -40,7 +40,7 @@ librtemsbsp_a_SOURCES += startup/bspreset.c
 librtemsbsp_a_SOURCES += clock/clock-config.c
 # Timer
 # IRQ
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
diff --git a/c/src/lib/libbsp/sh/shsim/Makefile.am b/c/src/lib/libbsp/sh/shsim/Makefile.am
index 7f80ca99a9..fc3b9caf7f 100644
--- a/c/src/lib/libbsp/sh/shsim/Makefile.am
+++ b/c/src/lib/libbsp/sh/shsim/Makefile.am
@@ -38,7 +38,7 @@ librtemsbsp_a_SOURCES += console/console-support.S
 librtemsbsp_a_SOURCES += console/console-debugio.c
 # timer
 # Cache
diff --git a/c/src/lib/libbsp/sparc64/niagara/Makefile.am b/c/src/lib/libbsp/sparc64/niagara/Makefile.am
index f90c7ddfcd..20f56003bd 100644
--- a/c/src/lib/libbsp/sparc64/niagara/Makefile.am
+++ b/c/src/lib/libbsp/sparc64/niagara/Makefile.am
@@ -42,7 +42,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console-select.c
diff --git a/c/src/lib/libbsp/sparc64/usiii/Makefile.am b/c/src/lib/libbsp/sparc64/usiii/Makefile.am
index 3369039a8e..f80a89b77f 100644
--- a/c/src/lib/libbsp/sparc64/usiii/Makefile.am
+++ b/c/src/lib/libbsp/sparc64/usiii/Makefile.am
@@ -53,7 +53,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console
diff --git a/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am b/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
index cd487fec51..0506ed2a27 100644
--- a/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
+++ b/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
@@ -29,7 +29,7 @@ librtemsbsp_a_SOURCES += startup/trap.S
 # Cache
2.12.3
