[PATCH 24/40] bsps: Remove unused irq.h template file
Thu Apr 19 13:26:49 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
 c/src/lib/libbsp/shared/include/irq.h | 77 -----------------------------------
 1 file changed, 77 deletions(-)
 delete mode 100644 c/src/lib/libbsp/shared/include/irq.h
diff --git a/c/src/lib/libbsp/shared/include/irq.h b/c/src/lib/libbsp/shared/include/irq.h
deleted file mode 100644
index ca2a1d77f1..0000000000
--- a/c/src/lib/libbsp/shared/include/irq.h
+++ /dev/null
@@ -1,77 +0,0 @@
- * @file
- * @ingroup bsp_interrupt
- * @brief BSP interrupt support configuration template.
- * Based on concepts of Pavel Pisa, Till Straumann and Eric Valette.
- * Copyright (c) 2008, 2009, 2010
- * embedded brains GmbH
- * Obere Lagerstr. 30
- * D-82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifndef LIBBSP_SHARED_IRQ_CONFIG_H
-#define LIBBSP_SHARED_IRQ_CONFIG_H
-#include <stdint.h>
- * @brief Minimum vector number.
-#define BSP_INTERRUPT_VECTOR_MIN 0
- * @brief Maximum vector number.
-#define BSP_INTERRUPT_VECTOR_MAX 0
- * @brief Enables the index table.
- * If you enable the index table, you have to define a size for the handler
- * table (@ref BSP_INTERRUPT_HANDLER_TABLE_SIZE) and must provide an integer
- * type capable to index the complete handler table (@ref
- * bsp_interrupt_handler_index_type).
-#undef BSP_INTERRUPT_USE_INDEX_TABLE
- * @brief Disables usage of the heap.
- * If you define this, you have to define @ref BSP_INTERRUPT_USE_INDEX_TABLE as
- * well.
-#undef BSP_INTERRUPT_NO_HEAP_USAGE
-#ifdef BSP_INTERRUPT_USE_INDEX_TABLE
-   * @brief Size of the handler table.
-  #define BSP_INTERRUPT_HANDLER_TABLE_SIZE 0
-   * @brief Integer type capable to index the complete handler table.
-  typedef uint8_t bsp_interrupt_handler_index_type;
-#endif
- * @brief Enable custom vector checking
- * If defined the BSP must implement the custom bsp_interrupt_is_valid_vector()
- * vector validator check routine.
-#undef BSP_INTERRUPT_CUSTOM_VALID_VECTOR
-#endif /* LIBBSP_SHARED_IRQ_CONFIG_H */
2.12.3
