BSP source re-organization status
Mon Apr 23 05:37:13 UTC 2018
On 23/04/18 03:08, Chris Johns wrote:
> On 20/04/2018 23:23, Sebastian Huber wrote:
>> PS: How can I use brackets { and } in a :file:`...{...}...` directive?
> Found and tested:
>   :file:`c/src/lib/libbsp/${{CPU}}/${{BSP}}/startup/bspstart.c`
> worked.
No, this doesn't work:
<p>The BSPs are all under the <a class="reference external"
href="https://git.rtems.org/rtems/tree/bsps">bsps</a>
directory.  The structure in this source subtree is:</p>
<ul class="simple">
<li><code class="file docutils literal"><span
class="pre">bsps/shared</span></code></li>
class="pre">bsps/$</span><em><span
class="pre">{RTEMS_CPU</span></em><span
class="pre">}/shared</span></code></li>
class="pre">{RTEMS_CPU</span></em><span class="pre">}/$</span><em><span
class="pre">{RTEMS_BSP_FAMILY</span></em><span
class="pre">}</span></code></li>
</ul>
Please note the generation of "<em><span class="pre">...</em>" blocks.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
