[PATCH] bootstrap: Do not create acinlude.m4 files
Mon Apr 23 07:32:50 UTC 2018
On 23/4/18 5:07 pm, Sebastian Huber wrote:
> On 23/04/18 08:51, Chris Johns wrote:
>>> A RSB script
>>> which modifies files of the repository is an extra error source.
>> Why not remove `generate_bspdir_acinclude()` from the bootstrap script and we
>> maintained the file by hand? After all adding or removing BSPs from RTEMS is not
>> done that often and is a manual process anyway.
>> Doing this also means both processes to bootstrap are the same which is a good
>> outcome.
> Maintaining this file by hand is not a big deal. I will remove the stuff from
> the bootstrap script.
This patch is OK to push when you push the bootstrap change.
This is a good change, making things simpler.
Thank you.
