[PATCH 0/2] *** Covoar Outstanding Changes ***
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat Apr 28 10:11:31 UTC 2018
On 28 April 2018 at 01:25, Chris Johns <chrisj at rtems.org> wrote:
> On 28/4/18 7:41 am, Cillian O'Donnell wrote:
> > On 26 April 2018 at 08:50, Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 26/04/2018 16:11, Cillian O'Donnell wrote:
> > > On Thu, 26 Apr 2018, 03:27 Chris Johns, <chrisj at rtems.org <mailto:
> > > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> > >> Also, are there any RSB changes outstanding to build a suitable
> QEMU?
> > > Oh yes, I still have that build. I'll take a look at it tonight,
> see if it's
> > > still ok.
> > Thank you. I can then look at testing those changes as well.
> > Just ran the rsb build there, it finishes with no error messages and
> appears to
> > be successful but no tools end up in the prefix location. Nothing
> obviously
> > wrong in the log. Have you seen that before? Same thing with the qemu
> that's
> > currently in the rsb. Has anyone tried to build qemu with the rsb
> recently?
> Yes, I happened to build it yesterday on FreeBSD:
> $ ../source-builder/sb-set-builder --prefix=/opt/work/rtems/qemu \
> --log=qemu.txt devel/qemu
> $ ls /opt/work/rtems/qemu/bin
> autopoint qemu-system-i386
> envsubst qemu-system-lm32
> gettext qemu-system-m68k
> gettext.sh qemu-system-microblaze
> gettextize qemu-system-microblazeel
> msgattrib qemu-system-mips
> msgcat qemu-system-mips64
> msgcmp qemu-system-mips64el
> msgcomm qemu-system-mipsel
> msgconv qemu-system-moxie
> msgen qemu-system-or32
> msgexec qemu-system-ppc
> msgfilter qemu-system-ppc64
> msgfmt qemu-system-ppcemb
> msggrep qemu-system-s390x
> msginit qemu-system-sh4
> msgmerge qemu-system-sh4eb
> msgunfmt qemu-system-sparc
> msguniq qemu-system-sparc64
> ngettext qemu-system-tricore
> qemu-ga qemu-system-unicore32
> qemu-i386 qemu-system-x86_64
> qemu-sparc qemu-system-xtensa
> qemu-sparc64 qemu-system-xtensaeb
> qemu-system-aarch64 qemu-x86_64
> qemu-system-alpha recode-sr-latin
> qemu-system-arm xgettext
> qemu-system-cris
> Is there a patch I download and test?
Hmmm, well if that's working for you then the couverture build should be
fine, they're fairly similar. I'll send the patches in now.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180428/b2415547/attachment.html>
