[PATCH] covoar: Add symbol set reader and ELF data parser to covoar.
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat Apr 28 22:27:37 UTC 2018
On Sat, 28 Apr 2018, 20:39 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> This is the log file that I'm getting after running the test
> I'm getting a lot of 'invalid' results , am I missing something ?
What we had in coverage.py and test.py will need to be updated with Chris'
change to covoar. It's probably best not to run it with rtems-test until
we've revised that. We'll just be testing covoar by itself for the moment.
The focus will probably be on removing covoars dependency on external tools
next.
Chris will we pass in the score ini to -S option now and then the other
options are picked up from there? (Excluding -p and -E).
> after this patch along with with the c++ cleanup patch, we have to start
> working on parsing the coverage right?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180428/a517c16e/attachment.html>
