[PATCH] covoar: Add symbol set reader and ELF data parser to covoar.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Apr 28 22:29:59 UTC 2018
On Sun, 29 Apr 2018, 03:57 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
> On Sat, 28 Apr 2018, 20:39 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> This is the log file that I'm getting after running the test
>> I'm getting a lot of 'invalid' results , am I missing something ?
> What we had in coverage.py and test.py will need to be updated with Chris'
> change to covoar. It's probably best not to run it with rtems-test until
> we've revised that. We'll just be testing covoar by itself for the moment.
> The focus will probably be on removing covoars dependency on external tools
> next.
Understood
> Chris will we pass in the score ini to -S option now and then the other
> options are picked up from there? (Excluding -p and -E).
>> after this patch along with with the c++ cleanup patch, we have to start
>> working on parsing the coverage right?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180428/df655967/attachment-0001.html>
