error while running rtems-test with coverage
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Apr 4 10:18:49 UTC 2018
I got the rtems-test running
I found that get_item_names(section, err) in configuration.py  was
returning an empty list to the
item_names in load(bsp,opts) for config.py this was giving out the error
mandatory item not found .
I have attached the patch file .
current status :
rtems-test is running without coverage
running coverage gives the following error :
RTEMS Testing - Tester, 5 (092c569e81ae)
Traceback (most recent call last):
  File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
line 40, in <module>
    rt.test.run()
  File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
line 310, in run
    coverage = coverage_get_obj(opts, path_to_builddir[1])
line 230, in coverage_get_obj
    coverage_obj = coverage.coverage_run(opts.defaults, path_to_builddir)
  File "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py",
line 335, in __init__
    self.report_format = self.config_map['report_format'][2]
TypeError: 'NoneType' object has no attribute '__getitem__'
Thanks
-- vijay
On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
> > after pulling the ini-update branch from
> > https://github.com/cillianodonnell/rtems-tools/tree/ini-update
> Any local changes?
> > I tried running the rtems-test with the following command
> > $HOME/development/rtems/rtems-tools/tester/rtems-test
> > --rtems-tools=$HOME/development/rtems/5 --log=coverage_analysis.log
> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
> development/rtems/kernel/leon3
> > sparc-rtems5/c/leon3/testsuites/samples
> > was getting the KeyError for 'coverage'
> Please paste the command and output as it appears in the terminal?
> > current status :
> > the same command gives the error :
> > "mandatory item not found in bsp section : bsp,"
> > to make sure I didn't break something , I also tried running from a
> freshly
> > downloaded directory as well, it gives the same error.
> Did you try running the following command from the top of the source tree:
>  $ grep -r "mandatory item not found" *
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180404/3dd39b79/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180404/3dd39b79/attachment-0002.bin>
