error while running rtems-test with coverage
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu Apr 5 20:54:46 UTC 2018
I tried to solve the empty get in the way shown in the patch , but it
doesn't seems to work, I'm getting the following error now
RTEMS Testing - Tester, 5 (1ed6e2e64090)
Traceback (most recent call last):
  File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
line 40, in <module>
    rt.test.run()
  File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
line 303, in run
    bsp = config.load(bsp[1], opts)
  File "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py",
line 461, in load
    return opts.defaults['bsp']
  File
"/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py", line
190, in __getitem__
    raise IndexError('key: %s' % (key))
IndexError: key: bsp
-- vijay
On 5 April 2018 at 11:51, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> I got the rtems-test running
>> I found that get_item_names(section, err) in configuration.py  was
>> returning an empty list to the
>> item_names in load(bsp,opts) for config.py this was giving out the error
>> mandatory item not found .
>> I have attached the patch file .
>> current status :
>> rtems-test is running without coverage
>> running coverage gives the following error :
>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>     rt.test.run()
>> line 310, in run
>>     coverage = coverage_get_obj(opts, path_to_builddir[1])
>> line 230, in coverage_get_obj
>>     coverage_obj = coverage.coverage_run(opts.defaults, path_to_builddir)
>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py",
>> line 335, in __init__
>>     self.report_format = self.config_map['report_format'][2]
> This is back to the difference in cfg formats. It's looking for the last
> line here
> https://github.com/cillianodonnell/rtems-tools/blob/coverage/tester/rtems/
> testing/bsps/leon3-qemu.mc
> Which is now
> blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
> It's trying to grab the 'html' text so it can trigger the right section of
> code in coverage.py
> It's something just to tell which format we want the report to output
Understood , I'll come to that after I manage to get the test running first
> TypeError: 'NoneType' object has no attribute '__getitem__'
>> Thanks
>> -- vijay
>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>> > after pulling the ini-update branch from
>>> > https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>> Any local changes?
>>> > I tried running the rtems-test with the following command
>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>> > --rtems-tools=$HOME/development/rtems/5 --log=coverage_analysis.log
>>> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
>>> development/rtems/kernel/leon3
>>> > sparc-rtems5/c/leon3/testsuites/samples
>>> > was getting the KeyError for 'coverage'
>>> Please paste the command and output as it appears in the terminal?
>>> > current status :
>>> > the same command gives the error :
>>> > "mandatory item not found in bsp section : bsp,"
>>> > to make sure I didn't break something , I also tried running from a
>>> freshly
>>> > downloaded directory as well, it gives the same error.
>>> Did you try running the following command from the top of the source
>>> tree:
>>>  $ grep -r "mandatory item not found" *
>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180406/7b4f586a/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180406/7b4f586a/attachment-0002.bin>
