error while running rtems-test with coverage
Cillian O'Donnell
cpodonnell8 at gmail.com
Thu Apr 5 06:21:06 UTC 2018
On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> I got the rtems-test running
> I found that get_item_names(section, err) in configuration.py was
> returning an empty list to the
> item_names in load(bsp,opts) for config.py this was giving out the error
> mandatory item not found .
> I have attached the patch file .
> current status :
> rtems-test is running without coverage
> running coverage gives the following error :
> RTEMS Testing - Tester, 5 (092c569e81ae)
> Traceback (most recent call last):
> File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
> line 40, in <module>
> rt.test.run()
> File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
> line 310, in run
> coverage = coverage_get_obj(opts, path_to_builddir[1])
> line 230, in coverage_get_obj
> coverage_obj = coverage.coverage_run(opts.defaults, path_to_builddir)
> File
> "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py", line
> 335, in __init__
> self.report_format = self.config_map['report_format'][2]
This is back to the difference in cfg formats. It's looking for the last
line here
https://github.com/cillianodonnell/rtems-tools/blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
Which is now
https://github.com/cillianodonnell/rtems-tools/blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
It's trying to grab the 'html' text so it can trigger the right section of
code in coverage.py
It's something just to tell which format we want the report to output
TypeError: 'NoneType' object has no attribute '__getitem__'
> Thanks
> -- vijay
> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>> > after pulling the ini-update branch from
>> > https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>> Any local changes?
>> > I tried running the rtems-test with the following command
>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>> > --rtems-tools=$HOME/development/rtems/5 --log=coverage_analysis.log
>> > --rtems-bsp=leon3_qemu
>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>> > sparc-rtems5/c/leon3/testsuites/samples
>> > was getting the KeyError for 'coverage'
>> Please paste the command and output as it appears in the terminal?
>> > current status :
>> > the same command gives the error :
>> > "mandatory item not found in bsp section : bsp,"
>> > to make sure I didn't break something , I also tried running from a
>> freshly
>> > downloaded directory as well, it gives the same error.
>> Did you try running the following command from the top of the source tree:
>> $ grep -r "mandatory item not found" *
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180405/3744f51c/attachment-0002.html>
