error while running rtems-test with coverage
Cillian O'Donnell cpodonnell8 at gmail.com
Fri Apr 13 18:10:45 UTC 2018
Is there anywhere in that output that it shows the qemu command that is
running?
On Fri, 13 Apr 2018, 19:02 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> -- vijay
> On 13 April 2018 at 23:29, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> I can't say for certain but I don't think that will be visible to
>> qemu.cfg unless it's a global variable. Chris might know off the top of his
>> head.
>> On Fri, 13 Apr 2018, 18:51 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> can we set it in [coverage] ?
>>> It runs with the same warnings of unable to read the .cov files
>> -- vijay
>>> On 13 April 2018 at 23:15, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Alright so we're back to ini update stuff. That error is because in the
>>>> old leon3-qemu.mc we had this global variable set. So you need to find
>>>> out how to get that global variable set in the new leon3-qemu.ini
>>>> Heres the old version from the .MC file
>>>> [global]
>>>> bsp:                      none,    none,     'leon3'
>>>> coverage_supported:       none,    none,     '1'
>>>> On Fri, 13 Apr 2018, 18:29 Vijay Kumar Banerjee, <
>>>>> It shows the following error
>>>>> RTEMS Testing - Tester, 5 (58acb6d61ac7 modified)
>>>>> Coverage environment prepared
>>>>> [ 3/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>> sparc/leon3_qemu: cdtest.exe
>>>>> [ 1/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>> sparc/leon3_qemu: base_sp.exe
>>>>> [ 2/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>> sparc/leon3_qemu: capture.exe
>>>>> [ 4/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>> sparc/leon3_qemu: fileio.exe
>>>>> error: qemu.cfg:77: macro '%{coverage_supported}' not found
>>>>> warning: switched to dry run due to errors
>>>>> error: qemu.cfg:77: invalid if bool value:  %if %{coverage_supported}
>>>>> Traceback (most recent call last):
>>>>>   File
>>>>> "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test", line
>>>>> 40, in <module>
>>>>>     rt.test.run()
>>>>>   File
>>>>> "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py", line
>>>>> 353, in run
>>>>>     tst.reraise()
>>>>>   File
>>>>> 160, in reraise
>>>>>     _test_reraise(*self.result)
>>>>> NameError: global name '_test_reraise' is not defined
>>>>> -- vijay
>>>>> On 13 April 2018 at 22:54, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> Ah yes, your missing the qemu arguments to run the coverage. Try this
>>>>>> # Coverage analysis
>>>>>> %define coverage_arg %{nil}
>>>>>> %if %{defined _coverage}
>>>>>>         %define coverage_arg -exec-trace %{test_executable}.cov
>>>>>>     %else
>>>>>>         %error "Coverage analysis unsupported for %{bsp}"
>>>>>>     %endif
>>>>>> %endif
>>>>>> # Executable
>>>>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel %{test_executable} %{coverage_arg}
>>>>>> On Fri, 13 Apr 2018, 18:18 Vijay Kumar Banerjee, <
>>>>>>> sure
>>>>>>> # RTEMS Tools Project (http://www.rtems.org/)
>>>>>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>>>>>> # All rights reserved.
>>>>>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>>> # Redistribution and use in source and binary forms, with or without
>>>>>>> # modification, are permitted provided that the following conditions
>>>>>>> are met:
>>>>>>> # 1. Redistributions of source code must retain the above copyright
>>>>>>> notice,
>>>>>>> # this list of conditions and the following disclaimer.
>>>>>>> # 2. Redistributions in binary form must reproduce the above
>>>>>>> copyright notice,
>>>>>>> # this list of conditions and the following disclaimer in the
>>>>>>> documentation
>>>>>>> # and/or other materials provided with the distribution.
>>>>>>> # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>> CONTRIBUTORS "AS IS"
>>>>>>> # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>>>> TO, THE
>>>>>>> # IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>>>>> PURPOSE
>>>>>>> # ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>>> CONTRIBUTORS BE
>>>>>>> # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>>>>> # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>>>>>> OF
>>>>>>> # SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>>> BUSINESS
>>>>>>> # INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>>> WHETHER IN
>>>>>>> # CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>>> OTHERWISE)
>>>>>>> # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>>> ADVISED OF THE
>>>>>>> # POSSIBILITY OF SUCH DAMAGE.
>>>>>>> # QEMU
>>>>>>> # Use a qemu command to run the executable in the qemu simulator.
>>>>>>> %include %{_configdir}/base.cfg
>>>>>>> %include %{_configdir}/checks.cfg
>>>>>>> # Console.
>>>>>>> %define console_stdio
>>>>>>> %include %{_configdir}/console.cfg
>>>>>>> # RTEMS version
>>>>>>> %include %{_rtdir}/rtems/version.cfg
>>>>>>> # Qemu common option patterns.
>>>>>>> #%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>>>> -nographic
>>>>>>> #%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>>>> -nographic
>>>>>>> %define qemu_opts_base  -no-reboot -monitor null -serial stdio
>>>>>>> -nographic
>>>>>>> %define qemu_opts_no_net -net none
>>>>>>> # Qemu executable
>>>>>>> %ifn %{defined bsp_qemu_opts}
>>>>>>>  %define bsp_qemu_opts %{nil}
>>>>>>> %endif
>>>>>>> %define qemu_cmd  qemu-system-%{bsp_arch}
>>>>>>> %define qemu_opts %{bsp_qemu_opts}
>>>>>>> # Executable
>>>>>>> %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>>>>>> -- vijay
>>>>>>> On 13 April 2018 at 22:19, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Yeah that's fine but can you just paste the contents here anyway.
>>>>>>>> I'm not near a laptop and I can't remember which branch your starting from.
>>>>>>>> On Fri, 13 Apr 2018, 13:51 Vijay Kumar Banerjee, <
>>>>>>>>> I haven't made any local changes to qemu.cfg
>>>>>>>>> -- vijay
>>>>>>>>> On 13 April 2018 at 11:43, Cillian O'Donnell <
>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>> No that's the right one. I think it might be something to do with
>>>>>>>>>> qemu.cfg in rtems-tools then. What's in your qemu.cfg? It's in
>>>>>>>>>> rtems-tools/tester/rtems/testing
>>>>>>>>>> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <
>>>>>>>>>>> I manually built qemu from here
>>>>>>>>>>> https://github.com/AdaCore/qemu
>>>>>>>>>>> I guess this is regular qemu , please send a link for couverture
>>>>>>>>>>> qemu for manual build.
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 12 April 2018 at 22:23, Cillian O'Donnell <
>>>>>>>>>>>> Ah that's good progress, those .cov files are supposed to be
>>>>>>>>>>>> generated by couverture-qemu as the test are run. They contain the trace
>>>>>>>>>>>> data. Are you definitely running couverture-qemu and not regular qemu?
>>>>>>>>>>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>>>>>>>>>>>> I got the parsing of the coverage from the ini file running ,
>>>>>>>>>>>>> now I'm getting the following error and warnings .
>>>>>>>>>>>>> Running covoar for score
>>>>>>>>>>>>> WARNING: Unable to read coverage file
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/capture/capture.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/fileio/fileio.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/iostream/cxx_iostream.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/loopback/loopback.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/minimum/minimum.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/nsecs/nsecs.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/paranoia/paranoia.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/pppd/pppd.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/ticker/ticker.exe.cov
>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe.cov
>>>>>>>>>>>>> ERROR: No information to analyze
>>>>>>>>>>>>> ***Cleaning tempfiles***
>>>>>>>>>>>>> error: covoar failure exit code: 1
>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>>>>>>>>>>> I managed to get the tests running with the following two
>>>>>>>>>>>>>> patches .
>>>>>>>>>>>>>> Please review them .
>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>> I tried to solve the empty get in the way shown in the
>>>>>>>>>>>>>>>> patch , but it doesn't seems to work, I'm getting the following error now
>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test", line 40,
>>>>>>>>>>>>>>>> in <module>
>>>>>>>>>>>>>>>>     rt.test.run()
>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 303,
>>>>>>>>>>>>>>>> in run
>>>>>>>>>>>>>>>>     bsp = config.load(bsp[1], opts)
>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py", line
>>>>>>>>>>>>>>>> 461, in load
>>>>>>>>>>>>>>>>     return opts.defaults['bsp']
>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py", line
>>>>>>>>>>>>>>>> 190, in __getitem__
>>>>>>>>>>>>>>>>     raise IndexError('key: %s' % (key))
>>>>>>>>>>>>>>>> IndexError: key: bsp
>>>>>>>>>>>>>>>> I still Couldn't figure out why it's happening, when I use
>>>>>>>>>>>>>>> RawConfigParse , it seems to run nicely though .
>>>>>>>>>>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <
>>>>>>>>>>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>>> I got the rtems-test running
>>>>>>>>>>>>>>>>>> I found that get_item_names(section, err) in
>>>>>>>>>>>>>>>>>> configuration.py  was returning an empty list to the
>>>>>>>>>>>>>>>>>> item_names in load(bsp,opts) for config.py this was
>>>>>>>>>>>>>>>>>> giving out the error mandatory item not found .
>>>>>>>>>>>>>>>>>> I have attached the patch file .
>>>>>>>>>>>>>>>>>> current status :
>>>>>>>>>>>>>>>>>> rtems-test is running without coverage
>>>>>>>>>>>>>>>>>> running coverage gives the following error :
>>>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>> in <module>
>>>>>>>>>>>>>>>>>>     rt.test.run()
>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 310,
>>>>>>>>>>>>>>>>>> in run
>>>>>>>>>>>>>>>>>>     coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 230,
>>>>>>>>>>>>>>>>>> in coverage_get_obj
>>>>>>>>>>>>>>>>>>     coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>>>>>>>>>>> path_to_builddir)
>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py", line
>>>>>>>>>>>>>>>>>> 335, in __init__
>>>>>>>>>>>>>>>>>>     self.report_format =
>>>>>>>>>>>>>>>>>> self.config_map['report_format'][2]
>>>>>>>>>>>>>>>>> This is back to the difference in cfg formats. It's
>>>>>>>>>>>>>>>>> looking for the last line here
>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>>>>>>>>>>> Which is now
>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>>>>>>>>>>>> It's trying to grab the 'html' text so it can trigger the
>>>>>>>>>>>>>>>>> right section of code in coverage.py
>>>>>>>>>>>>>>>>> It's something just to tell which format we want the
>>>>>>>>>>>>>>>>> report to output
>>>>>>>>>>>>>>>> Understood , I'll come to that after I manage to get the
>>>>>>>>>>>>>>>> test running first .
>>>>>>>>>>>>>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org>
>>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>>>>>>>>>>> Any local changes?
>>>>>>>>>>>>>>>>>>> > I tried running the rtems-test with the following
>>>>>>>>>>>>>>>>>>> command
>>>>>>>>>>>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>> --log=coverage_analysis.log
>>>>>>>>>>>>>>>>>>> > --rtems-bsp=leon3_qemu
>>>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>>>>>>>>>>> Please paste the command and output as it appears in the
>>>>>>>>>>>>>>>>>>> terminal?
>>>>>>>>>>>>>>>>>>> > current status :
>>>>>>>>>>>>>>>>>>> > the same command gives the error :
>>>>>>>>>>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>>>>>>>>>>> > to make sure I didn't break something , I also tried
>>>>>>>>>>>>>>>>>>> running from a freshly
>>>>>>>>>>>>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>>>>>>>>>>>>> Did you try running the following command from the top
>>>>>>>>>>>>>>>>>>> of the source tree:
>>>>>>>>>>>>>>>>>>>  $ grep -r "mandatory item not found" *
>>>>>>>>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/c068152f/attachment-0002.html>
