error while running rtems-test with coverage
Cillian O'Donnell cpodonnell8 at gmail.com
Fri Apr 13 18:21:08 UTC 2018
Hmmm it's not there. Even so I can almost guarantee you, the reason it's
not running is that coverage_supported variable is not being found as true
in qemu.cfg and so the the command to generated the trace files isn't run
and there's no .cov files in the end. So that's what you'll have to dig
into.
On Fri, 13 Apr 2018, 19:16 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> It just shows this.(with only hello)
> Running covoar for score
> WARNING: Unable to read coverage file
> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe.cov
> ERROR: No information to analyze
> ***Cleaning tempfiles***
> error: covoar failure exit code: 1
> The log file shows this
> RTEMS Testing - Tester, 5 (58acb6d61ac7 modified)
>   2  Command Line:
> /home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test
> --rtems-t    ools=/home/lunatic/development/rtems/5
> --log=coverage_analysis.log --rtems-bsp=leon3_qemu -    -coverage
> --rtems-builddir=/home/lunatic/development/rtems/kernel/leon3
> sparc-rtems5/c/leon    3/testsuites/samples/hello
>   3  Python: 2.7.14 (default, Feb 27 2018, 20:43:24) [GCC 7.3.1 20180130
> (Red Hat 7.3.1-2)]
>   4 Host: Linux-4.15.8-300.fc27.x86_64-x86_64-with-fedora-27-Twenty_Seven
> (Linux lunatic 4.15.8    -300.fc27.x86_64 #1 SMP Fri Mar 9 18:11:36 UTC
> 2018 x86_64 x86_64)
>   5 Coverage environment prepared
>   6 [1/1] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | sparc/leon3_qemu: hello.exe
>   7
>   8 Passed:        1
>   9 Failed:        0
>  10 User Input:    0
>  11 Expected Fail: 0
>  12 Indeterminate: 0
>  13 Benchmark:     0
>  14 Timeout:       0
>  15 Invalid:       0
>  16 Wrong Version: 0
>  17 Wrong Build:   0
>  18 Wrong Tools:   0
>  19 ----------------
>  20 Total:         1
>  21
>  22 Average test time: 0:00:01.505199
>  23 Testing time     : 0:00:01.505199
>  24 Running covoar for score
>  25 shell: covoar -s /home/lunatic/coverage_test/coverage/score.symcfg -O
> /home/lunatic/coverag    e_test/test/score -f QEMU -T sparc-rtems5 -E
> ls/tester/rtems/testing/coverage/Explanations.txt -c .cov -e exe -p RTEMS-5
> /home/lunatic/d
>  26 WARNING: Unable to read coverage file
>    1,1           Top
> -- vijay
> On 13 April 2018 at 23:40, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> Is there anywhere in that output that it shows the qemu command that is
>> running?
>> On Fri, 13 Apr 2018, 19:02 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> -- vijay
>>> On 13 April 2018 at 23:29, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> I can't say for certain but I don't think that will be visible to
>>>> qemu.cfg unless it's a global variable. Chris might know off the top of his
>>>> head.
>>>> On Fri, 13 Apr 2018, 18:51 Vijay Kumar Banerjee, <
>>>>> can we set it in [coverage] ?
>>>>> It runs with the same warnings of unable to read the .cov files
>>>> -- vijay
>>>>> On 13 April 2018 at 23:15, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> Alright so we're back to ini update stuff. That error is because in
>>>>>> the old leon3-qemu.mc we had this global variable set. So you need
>>>>>> to find out how to get that global variable set in the new leon3-qemu.ini
>>>>>> Heres the old version from the .MC file
>>>>>> [global]
>>>>>> bsp:                      none,    none,     'leon3'
>>>>>> coverage_supported:       none,    none,     '1'
>>>>>> On Fri, 13 Apr 2018, 18:29 Vijay Kumar Banerjee, <
>>>>>>> It shows the following error
>>>>>>> [ 3/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>>>> sparc/leon3_qemu: cdtest.exe
>>>>>>> [ 1/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>>>> sparc/leon3_qemu: base_sp.exe
>>>>>>> [ 2/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>>>> sparc/leon3_qemu: capture.exe
>>>>>>> [ 4/13] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>>>>>>> sparc/leon3_qemu: fileio.exe
>>>>>>> error: qemu.cfg:77: macro '%{coverage_supported}' not found
>>>>>>> warning: switched to dry run due to errors
>>>>>>> error: qemu.cfg:77: invalid if bool value:  %if %{coverage_supported}
>>>>>>> Traceback (most recent call last):
>>>>>>>   File
>>>>>>> "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test", line
>>>>>>> 40, in <module>
>>>>>>>     rt.test.run()
>>>>>>>   File
>>>>>>> "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py", line
>>>>>>> 353, in run
>>>>>>>     tst.reraise()
>>>>>>>   File
>>>>>>> 160, in reraise
>>>>>>>     _test_reraise(*self.result)
>>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>>> -- vijay
>>>>>>> On 13 April 2018 at 22:54, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Ah yes, your missing the qemu arguments to run the coverage. Try
>>>>>>>> this
>>>>>>>> # Coverage analysis
>>>>>>>> %define coverage_arg %{nil}
>>>>>>>> %if %{defined _coverage}
>>>>>>>>         %define coverage_arg -exec-trace %{test_executable}.cov
>>>>>>>>     %else
>>>>>>>>         %error "Coverage analysis unsupported for %{bsp}"
>>>>>>>>     %endif
>>>>>>>> %endif
>>>>>>>> # Executable
>>>>>>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel %{test_executable} %{coverage_arg}
>>>>>>>> On Fri, 13 Apr 2018, 18:18 Vijay Kumar Banerjee, <
>>>>>>>>> sure
>>>>>>>>> # RTEMS Tools Project (http://www.rtems.org/)
>>>>>>>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>>>>>>>> # All rights reserved.
>>>>>>>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>>>>> # Redistribution and use in source and binary forms, with or
>>>>>>>>> without
>>>>>>>>> # modification, are permitted provided that the following
>>>>>>>>> conditions are met:
>>>>>>>>> # 1. Redistributions of source code must retain the above
>>>>>>>>> copyright notice,
>>>>>>>>> # this list of conditions and the following disclaimer.
>>>>>>>>> # 2. Redistributions in binary form must reproduce the above
>>>>>>>>> copyright notice,
>>>>>>>>> # this list of conditions and the following disclaimer in the
>>>>>>>>> documentation
>>>>>>>>> # and/or other materials provided with the distribution.
>>>>>>>>> # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>>>> CONTRIBUTORS "AS IS"
>>>>>>>>> # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>>>>> LIMITED TO, THE
>>>>>>>>> # IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>>>> PARTICULAR PURPOSE
>>>>>>>>> # ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>>>>> CONTRIBUTORS BE
>>>>>>>>> # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>>>>>>>> OR
>>>>>>>>> # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>>>> PROCUREMENT OF
>>>>>>>>> # SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>>>>> BUSINESS
>>>>>>>>> # INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>>>>> WHETHER IN
>>>>>>>>> # CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>>>>> OTHERWISE)
>>>>>>>>> # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>>>>> ADVISED OF THE
>>>>>>>>> # POSSIBILITY OF SUCH DAMAGE.
>>>>>>>>> # QEMU
>>>>>>>>> # Use a qemu command to run the executable in the qemu simulator.
>>>>>>>>> %include %{_configdir}/base.cfg
>>>>>>>>> %include %{_configdir}/checks.cfg
>>>>>>>>> # Console.
>>>>>>>>> %define console_stdio
>>>>>>>>> %include %{_configdir}/console.cfg
>>>>>>>>> # RTEMS version
>>>>>>>>> %include %{_rtdir}/rtems/version.cfg
>>>>>>>>> # Qemu common option patterns.
>>>>>>>>> #%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>>>>>> -nographic
>>>>>>>>> #%define qemu_opts_base   -no-reboot -serial null -serial
>>>>>>>>> mon:stdio -nographic
>>>>>>>>> %define qemu_opts_base  -no-reboot -monitor null -serial stdio
>>>>>>>>> -nographic
>>>>>>>>> %define qemu_opts_no_net -net none
>>>>>>>>> # Qemu executable
>>>>>>>>> %ifn %{defined bsp_qemu_opts}
>>>>>>>>>  %define bsp_qemu_opts %{nil}
>>>>>>>>> %endif
>>>>>>>>> %define qemu_cmd  qemu-system-%{bsp_arch}
>>>>>>>>> %define qemu_opts %{bsp_qemu_opts}
>>>>>>>>> # Executable
>>>>>>>>> %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>>>>>>>> -- vijay
>>>>>>>>> On 13 April 2018 at 22:19, Cillian O'Donnell <
>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>> Yeah that's fine but can you just paste the contents here anyway.
>>>>>>>>>> I'm not near a laptop and I can't remember which branch your starting from.
>>>>>>>>>> On Fri, 13 Apr 2018, 13:51 Vijay Kumar Banerjee, <
>>>>>>>>>>> I haven't made any local changes to qemu.cfg
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 13 April 2018 at 11:43, Cillian O'Donnell <
>>>>>>>>>>>> No that's the right one. I think it might be something to do
>>>>>>>>>>>> with qemu.cfg in rtems-tools then. What's in your qemu.cfg? It's in
>>>>>>>>>>>> rtems-tools/tester/rtems/testing
>>>>>>>>>>>> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <
>>>>>>>>>>>>> I manually built qemu from here
>>>>>>>>>>>>> https://github.com/AdaCore/qemu
>>>>>>>>>>>>> I guess this is regular qemu , please send a link for
>>>>>>>>>>>>> couverture qemu for manual build.
>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>> On 12 April 2018 at 22:23, Cillian O'Donnell <
>>>>>>>>>>>>>> Ah that's good progress, those .cov files are supposed to be
>>>>>>>>>>>>>> generated by couverture-qemu as the test are run. They contain the trace
>>>>>>>>>>>>>> data. Are you definitely running couverture-qemu and not regular qemu?
>>>>>>>>>>>>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>> I got the parsing of the coverage from the ini file running
>>>>>>>>>>>>>>> , now I'm getting the following error and warnings .
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/capture/capture.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/fileio/fileio.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/iostream/cxx_iostream.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/loopback/loopback.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/minimum/minimum.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/nsecs/nsecs.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/paranoia/paranoia.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/pppd/pppd.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/ticker/ticker.exe.cov
>>>>>>>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe.cov
>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>> I managed to get the tests running with the following two
>>>>>>>>>>>>>>>> patches .
>>>>>>>>>>>>>>>> Please review them .
>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>>> I tried to solve the empty get in the way shown in the
>>>>>>>>>>>>>>>>>> patch , but it doesn't seems to work, I'm getting the following error now
>>>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test", line 40,
>>>>>>>>>>>>>>>>>> in <module>
>>>>>>>>>>>>>>>>>>     rt.test.run()
>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 303,
>>>>>>>>>>>>>>>>>> in run
>>>>>>>>>>>>>>>>>>     bsp = config.load(bsp[1], opts)
>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py", line
>>>>>>>>>>>>>>>>>> 461, in load
>>>>>>>>>>>>>>>>>>     return opts.defaults['bsp']
>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py", line
>>>>>>>>>>>>>>>>>> 190, in __getitem__
>>>>>>>>>>>>>>>>>>     raise IndexError('key: %s' % (key))
>>>>>>>>>>>>>>>>>> IndexError: key: bsp
>>>>>>>>>>>>>>>>>> I still Couldn't figure out why it's happening, when I
>>>>>>>>>>>>>>>>> use RawConfigParse , it seems to run nicely though .
>>>>>>>>>>>>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>>>>> I got the rtems-test running
>>>>>>>>>>>>>>>>>>>> I found that get_item_names(section, err) in
>>>>>>>>>>>>>>>>>>>> configuration.py  was returning an empty list to the
>>>>>>>>>>>>>>>>>>>> item_names in load(bsp,opts) for config.py this was
>>>>>>>>>>>>>>>>>>>> giving out the error mandatory item not found .
>>>>>>>>>>>>>>>>>>>> I have attached the patch file .
>>>>>>>>>>>>>>>>>>>> current status :
>>>>>>>>>>>>>>>>>>>> rtems-test is running without coverage
>>>>>>>>>>>>>>>>>>>> running coverage gives the following error :
>>>>>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>>>> in <module>
>>>>>>>>>>>>>>>>>>>>     rt.test.run()
>>>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 310,
>>>>>>>>>>>>>>>>>>>> in run
>>>>>>>>>>>>>>>>>>>>     coverage = coverage_get_obj(opts,
>>>>>>>>>>>>>>>>>>>> path_to_builddir[1])
>>>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 230,
>>>>>>>>>>>>>>>>>>>> in coverage_get_obj
>>>>>>>>>>>>>>>>>>>>     coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>>>>>>>>>>>>> path_to_builddir)
>>>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py", line
>>>>>>>>>>>>>>>>>>>> 335, in __init__
>>>>>>>>>>>>>>>>>>>>     self.report_format =
>>>>>>>>>>>>>>>>>>>> self.config_map['report_format'][2]
>>>>>>>>>>>>>>>>>>> This is back to the difference in cfg formats. It's
>>>>>>>>>>>>>>>>>>> looking for the last line here
>>>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>>>>>>>>>>>>> Which is now
>>>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>>>>>>>>>>>>>> It's trying to grab the 'html' text so it can trigger
>>>>>>>>>>>>>>>>>>> the right section of code in coverage.py
>>>>>>>>>>>>>>>>>>> It's something just to tell which format we want the
>>>>>>>>>>>>>>>>>>> report to output
>>>>>>>>>>>>>>>>>> Understood , I'll come to that after I manage to get the
>>>>>>>>>>>>>>>>>> test running first .
>>>>>>>>>>>>>>>>>>> TypeError: 'NoneType' object has no attribute
>>>>>>>>>>>>>>>>>>>> '__getitem__'
>>>>>>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org
>>>>>>>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>>>>>>>>>>>>> Any local changes?
>>>>>>>>>>>>>>>>>>>>> > I tried running the rtems-test with the following
>>>>>>>>>>>>>>>>>>>>> command
>>>>>>>>>>>>>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>>>>>>>>>>>>> Please paste the command and output as it appears in
>>>>>>>>>>>>>>>>>>>>> the terminal?
>>>>>>>>>>>>>>>>>>>>> > current status :
>>>>>>>>>>>>>>>>>>>>> > the same command gives the error :
>>>>>>>>>>>>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>>>>>>>>>>>>> > to make sure I didn't break something , I also tried
>>>>>>>>>>>>>>>>>>>>> running from a freshly
>>>>>>>>>>>>>>>>>>>>> > downloaded directory as well, it gives the same
>>>>>>>>>>>>>>>>>>>>> error.
>>>>>>>>>>>>>>>>>>>>> Did you try running the following command from the top
>>>>>>>>>>>>>>>>>>>>> of the source tree:
>>>>>>>>>>>>>>>>>>>>>  $ grep -r "mandatory item not found" *
>>>>>>>>>>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/60661dd5/attachment-0002.html>
