error while running rtems-test with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Apr 14 19:37:58 UTC 2018
-- vijay
On 15 April 2018 at 00:50, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 14 April 2018 at 16:42, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org> wrote:
>>> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>>>> Getting this error now seems like something is missing.
>>>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>>>> Coverage environment prepared
>>>> Traceback (most recent call last):
>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test",
>>>> line 40, in <module>
>>>> rt.test.run()
>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py",
>>>> line 353, in run
>>>> tst.reraise()
>>>> line 160, in reraise
>>>> _test_reraise(*self.result)
>>>> NameError: global name '_test_reraise' is not defined
>>> The reraise logic was moved to the rtemstoolkit last year:
>>> https://git.rtems.org/rtems-tools/commit/?id=fa81491764861e6
>>> 3785a3faa241c488469087209
>>> It had some issues that have been fixed and it is being reused else
>>> where in the tester.
>>>> -- vijay
>>>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>>>> On 13 April 2018 at 23:51, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>> <mailto:cpodonnell8 at gmail.com>> wrote:
>>>> Hmmm it's not there. Even so I can almost guarantee you, the
>>>> reason it's not running is that coverage_supported variable is
>>>> not being found as true in qemu.cfg and so the the command to
>>>> generated the trace files isn't run and there's no .cov files in
>>>> the end. So that's what you'll have to dig into.
>>>> Okay , I'll set it to global then.
>>> Changes need to be on the latest version of master before I will review
>>> them. The failure above indicate the code you have is not up to date.
>> Yes that was the plan. Just to check Vijay your starting point was using
>> the ini-update branch from here?
>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>> That branch is current rtems-tools master that I started to add things
>> back in. The only reraise in there is the one improrted from rtemstoolkit.
> yes this is the branch I'm using , I checked the reraise error , not sure
> how it showed up buit I called it from the reraise module , and it got
> fixed . now I'm stuck here
> error: config error: qemu.cfg:36: No 'target' defined
okay , fixed that .
still getting the warnings of the unable to read .cov
> are we supposed to set the bsp to global as well ?
>>> The change you have made is generating an exception in the tester
>>> thread. If you want to continue down this path you will need to fix what
>>> ever you have added.
>>> The tests are run as threads separate from the main thread so the
>>> exception is caught and re-raised in the main thread letting you know. This
>>> is broken in the old code base you are using.
>>> Why not investigate the reason as indicated and sort if out what the new
>>> format configuration file needs?
>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180415/a0353eee/attachment-0002.html>
