error while running rtems-test with coverage
Cillian O'Donnell cpodonnell8 at gmail.com
Sat Apr 14 20:15:07 UTC 2018
Switch one of these lines out in qemu.cfg.
#%define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio -nographic
%define qemu_opts_base -no-reboot -monitor null -serial stdio -nographic
Just comment out the one that's being used and uncomment one of the others.
It should cause a complaint when the tests are run and the qemu cmd should
show up in the log so we can take a look at it.
On 14 April 2018 at 20:37, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> -- vijay
> On 15 April 2018 at 00:50, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On 14 April 2018 at 16:42, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org> wrote:
>>>> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>>>>> Getting this error now seems like something is missing.
>>>>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>>>>> Coverage environment prepared
>>>>> Traceback (most recent call last):
>>>>>    File "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test",
>>>>> line 40, in <module>
>>>>>      rt.test.run()
>>>>>    File "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py",
>>>>> line 353, in run
>>>>>      tst.reraise()
>>>>> line 160, in reraise
>>>>>      _test_reraise(*self.result)
>>>>> NameError: global name '_test_reraise' is not defined
>>>> The reraise logic was moved to the rtemstoolkit last year:
>>>> https://git.rtems.org/rtems-tools/commit/?id=fa81491764861e6
>>>> 3785a3faa241c488469087209
>>>> It had some issues that have been fixed and it is being reused else
>>>> where in the tester.
>>>>> -- vijay
>>>>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <
>>>>> vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>>>>>     On 13 April 2018 at 23:51, Cillian O'Donnell <
>>>>>     <mailto:cpodonnell8 at gmail.com>> wrote:
>>>>>         Hmmm it's not there. Even so I can almost guarantee you, the
>>>>>         reason it's not running is that coverage_supported variable is
>>>>>         not being found as true in qemu.cfg and so the the command to
>>>>>         generated the trace files isn't run and there's no .cov files
>>>>> in
>>>>>         the end. So that's what you'll have to dig into.
>>>>>     Okay , I'll set it to global then.
>>>> Changes need to be on the latest version of master before I will review
>>>> them. The failure above indicate the code you have is not up to date.
>>> Yes that was the plan. Just to check Vijay your starting point was using
>>> the ini-update branch from here?
>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>> That branch is current rtems-tools master that I started to add things
>>> back in. The only reraise in there is the one improrted from rtemstoolkit.
>> yes this is the branch I'm using , I checked the reraise error , not
>> sure how it showed up buit I called it from the reraise module , and it
>> got fixed . now I'm stuck here
>> error: config error: qemu.cfg:36: No 'target' defined
> okay , fixed that .
> still getting the warnings of the unable to read .cov
>> are we supposed to set the bsp to global as well ?
>>>> The change you have made is generating an exception in the tester
>>>> thread. If you want to continue down this path you will need to fix what
>>>> ever you have added.
>>>> The tests are run as threads separate from the main thread so the
>>>> exception is caught and re-raised in the main thread letting you know. This
>>>> is broken in the old code base you are using.
>>>> Why not investigate the reason as indicated and sort if out what the
>>>> new format configuration file needs?
>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180414/b1f92e40/attachment-0002.html>
