error while running rtems-test with coverage
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon Apr 16 04:36:07 UTC 2018
On 15 April 2018 at 15:33, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On 15 April 2018 at 10:09, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> Not sure what's happening there. Send me a link to your github branch.
>> On 15 April 2018 at 09:35, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> On 15 April 2018 at 14:02, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On 15 April 2018 at 06:46, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> On 15 April 2018 at 01:45, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> Switch one of these lines out in qemu.cfg.
>>>>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>> -nographic
>>>>>> #%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>>>>> -nographic
>>>>>> %define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>>> -nographic
>>>>>> Just comment out the one that's being used and uncomment one of the
>>>>>> others. It should cause a complaint when the tests are run and the qemu cmd
>>>>>> should show up in the log so we can take a look at it.
>>>>> error: qemu.cfg:71: execute failed: qemu-system-sparc -no-reboot
>>>>> -monitor null -serial stdio -nographic -no-reboot -monitor null -serial
>>>>> stdio -nographic -M leon3_generic -kernel /home/lunatic/development/rtem
>>>>> s/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe:
>>>>> exit-code:1
>>>>> run: qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>> -nographic -no-reboot -mo    nitor null -serial stdio -nographic -M
>>>>> -exec-trace     /home/lunatic/development/rte
>>>>> ms/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimi
>>>>> ted/unlimited.exe.cov
>>>> Are those line breaks actually there or is it from the copy and paste.
>>>> Like  unlimi    ted. If so that's definitely the problem. What does your
>>>> last section in qemu.cfg look like now? The execute section.
>>> They are from copy paste .
>>> I'm pasting the qemu.cfg here
>>> # RTEMS Tools Project (http://www.rtems.org/)
>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>> # All rights reserved.
>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>> # Redistribution and use in source and binary forms, with or without
>>> # modification, are permitted provided that the following conditions are
>>> met:
>>> # 1. Redistributions of source code must retain the above copyright
>>> notice,
>>> # this list of conditions and the following disclaimer.
>>> # 2. Redistributions in binary form must reproduce the above copyright
>>> notice,
>>> # this list of conditions and the following disclaimer in the
>>> documentation
>>> # and/or other materials provided with the distribution.
>>> # this software is provided by the copyright holders and contributors
>>> "as is"
>>> # and any express or implied warranties, including, but not limited to,
>>> the
>>> # implied warranties of merchantability and fitness for a particular
>>> purpose
>>> # are disclaimed. in no event shall the copyright holder or contributors
>>> be
>>> # liable for any direct, indirect, incidental, special, exemplary, or
>>> # consequential damages (including, but not limited to, procurement of
>>> # substitute goods or services; loss of use, data, or profits; or
>>> business
>>> # interruption) however caused and on any theory of liability, whether in
>>> # contract, strict liability, or tort (including negligence or otherwise)
>>> # arising in any way out of the use of this software, even if advised of
>>> the
>>> # possibility of such damage.
>>> # qemu
>>> # use a qemu command to run the executable in the qemu simulator.
>>> %include %{_configdir}/base.cfg
>>> %include %{_configdir}/checks.cfg
>>> # console.
>>> %define console_stdio
>>> %include %{_configdir}/console.cfg
>>> # rtems version
>>> %include %{_rtdir}/rtems/version.cfg
>>> # qemu common option patterns.
>>> -nographic
>>> -nographic
>>> #%define qemu_opts_base  -no-reboot -monitor null -serial stdio
>>> -nographic
>>> %define qemu_opts_no_net -net none
>>> # qemu executable
>>> %ifn %{defined bsp_qemu_opts}
>>>  %define bsp_qemu_opts %{nil}
>>> %endif
>>> %define qemu_cmd  qemu-system-%{bsp_arch}
>>> %define qemu_opts %{bsp_qemu_opts}
>>> # Coverage analysis
>>> %define coverage_arg %{nil}
>>> %if %{defined _coverage}
>>>     %if %{coverage_supported}
>>>         %define coverage_arg -exec-trace %{test_executable}.cov
>>>     %else
>>>         %error "Coverage analysis unsupported for %{bsp}"
>>>     %endif
>>> %endif
>>> # executable
>>> #%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel
>>> %{test_executable} %{coverage_arg}
> Just get rid of  %{qemu_opts_base} (Theres a double count of options) and
> that should run without errors from the tester now. Unfortunately the
> report generated wont contain any data so we've moved on to problems in
> covoar now.
should I submit a patch now or should I apply the changes into current
master and them submit ?
>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
>>> -nographic
>>> #%define qemu_opts_base -no-reboot -monitor null -serial stdio -nographic
>>>>>> On 14 April 2018 at 20:37, Vijay Kumar Banerjee <
>>>>>>> -- vijay
>>>>>>> On 15 April 2018 at 00:50, Vijay Kumar Banerjee <
>>>>>>>> On 14 April 2018 at 16:42, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>>>> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>>>>>>>>>>> Getting this error now seems like something is missing.
>>>>>>>>>>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>>>>>>>>>>> Coverage environment prepared
>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>    File "/home/lunatic/development/rte
>>>>>>>>>>> ms/test/rtems-tools/tester/rtems-test", line 40, in <module>
>>>>>>>>>>>      rt.test.run()
>>>>>>>>>>> ms/test/rtems-tools/tester/rt/test.py", line 353, in run
>>>>>>>>>>>      tst.reraise()
>>>>>>>>>>> ms/test/rtems-tools/tester/rt/test.py", line 160, in reraise
>>>>>>>>>>>      _test_reraise(*self.result)
>>>>>>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>>>>>> The reraise logic was moved to the rtemstoolkit last year:
>>>>>>>>>> https://git.rtems.org/rtems-tools/commit/?id=fa81491764861e6
>>>>>>>>>> 3785a3faa241c488469087209
>>>>>>>>>> It had some issues that have been fixed and it is being reused
>>>>>>>>>> else where in the tester.
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <
>>>>>>>>>>> vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>
>>>>>>>>>>> wrote:
>>>>>>>>>>>     On 13 April 2018 at 23:51, Cillian O'Donnell <
>>>>>>>>>>>     <mailto:cpodonnell8 at gmail.com>> wrote:
>>>>>>>>>>>         Hmmm it's not there. Even so I can almost guarantee you,
>>>>>>>>>>> the
>>>>>>>>>>>         reason it's not running is that coverage_supported
>>>>>>>>>>> variable is
>>>>>>>>>>>         not being found as true in qemu.cfg and so the the
>>>>>>>>>>> command to
>>>>>>>>>>>         generated the trace files isn't run and there's no .cov
>>>>>>>>>>> files in
>>>>>>>>>>>         the end. So that's what you'll have to dig into.
>>>>>>>>>>>     Okay , I'll set it to global then.
>>>>>>>>>> Changes need to be on the latest version of master before I will
>>>>>>>>>> review them. The failure above indicate the code you have is not up to date.
>>>>>>>>> Yes that was the plan. Just to check Vijay your starting point was
>>>>>>>>> using the ini-update branch from here?
>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>> That branch is current rtems-tools master that I started to add
>>>>>>>>> things back in. The only reraise in there is the one improrted from
>>>>>>>>> rtemstoolkit.
>>>>>>>> yes this is the branch I'm using , I checked the reraise error , not
>>>>>>>> sure how it showed up buit I called it from the reraise module ,
>>>>>>>> and it got fixed . now I'm stuck here
>>>>>>>> error: config error: qemu.cfg:36: No 'target' defined
>>>>>>> okay , fixed that .
>>>>>>> still getting the warnings of the unable to read .cov
>>>>>>>> are we supposed to set the bsp to global as well ?
>>>>>>>>>> The change you have made is generating an exception in the tester
>>>>>>>>>> thread. If you want to continue down this path you will need to fix what
>>>>>>>>>> ever you have added.
>>>>>>>>>> The tests are run as threads separate from the main thread so the
>>>>>>>>>> exception is caught and re-raised in the main thread letting you know. This
>>>>>>>>>> is broken in the old code base you are using.
>>>>>>>>>> Why not investigate the reason as indicated and sort if out what
>>>>>>>>>> the new format configuration file needs?
>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180416/d1665303/attachment-0002.html>
