error while running rtems-test with coverage
Cillian O'Donnell cpodonnell8 at gmail.com
Mon Apr 16 05:43:44 UTC 2018
Probably what'll happen is, when the reports are generating properly, Chris
will review the changes and come up with a list of blockers that must be
fixed before he would be happy accepting the code into rtems-tools master.
Then when that's done you can submit the patches.
The thing with the data missing from the reports is tricky because there's
no error messages or log output to go on. Last time I seen that it was
because we were changing how the symbols were parsed and they were being
chopped up in odd ways and so none of them were found and so the report was
empty. This time I'm not sure because we haven't changed anything like
that. If I think of any clues, I'll let you know.
On Mon, 16 Apr 2018, 05:36 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 15 April 2018 at 15:33, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 15 April 2018 at 10:09, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> Not sure what's happening there. Send me a link to your github branch.
>>> On 15 April 2018 at 09:35, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 15 April 2018 at 14:02, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> On 15 April 2018 at 06:46, Vijay Kumar Banerjee <
>>>>>> On 15 April 2018 at 01:45, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> Switch one of these lines out in qemu.cfg.
>>>>>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>>> -nographic
>>>>>>> #%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>>>>>> -nographic
>>>>>>> %define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>>>> -nographic
>>>>>>> Just comment out the one that's being used and uncomment one of the
>>>>>>> others. It should cause a complaint when the tests are run and the qemu cmd
>>>>>>> should show up in the log so we can take a look at it.
>>>>>> error: qemu.cfg:71: execute failed: qemu-system-sparc -no-reboot
>>>>>> -monitor null -serial stdio -nographic -no-reboot -monitor null -serial
>>>>>> stdio -nographic -M leon3_generic -kernel
>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe:
>>>>>> exit-code:1
>>>>>> run: qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>> -nographic -no-reboot -mo    nitor null -serial stdio -nographic -M
>>>>>> leon3_generic -kernel /home/lunatic/development/rtem
>>>>>> -exec-trace
>>>>>>   ted/unlimited.exe.cov
>>>>> Are those line breaks actually there or is it from the copy and paste.
>>>>> Like  unlimi    ted. If so that's definitely the problem. What does your
>>>>> last section in qemu.cfg look like now? The execute section.
>>>> They are from copy paste .
>>>> I'm pasting the qemu.cfg here
>>>> # RTEMS Tools Project (http://www.rtems.org/)
>>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>>> # All rights reserved.
>>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>> # Redistribution and use in source and binary forms, with or without
>>>> # modification, are permitted provided that the following conditions
>>>> are met:
>>>> # 1. Redistributions of source code must retain the above copyright
>>>> notice,
>>>> # this list of conditions and the following disclaimer.
>>>> # 2. Redistributions in binary form must reproduce the above copyright
>>>> notice,
>>>> # this list of conditions and the following disclaimer in the
>>>> documentation
>>>> # and/or other materials provided with the distribution.
>>>> # this software is provided by the copyright holders and contributors
>>>> "as is"
>>>> # and any express or implied warranties, including, but not limited to,
>>>> the
>>>> # implied warranties of merchantability and fitness for a particular
>>>> purpose
>>>> # are disclaimed. in no event shall the copyright holder or
>>>> contributors be
>>>> # liable for any direct, indirect, incidental, special, exemplary, or
>>>> # consequential damages (including, but not limited to, procurement of
>>>> # substitute goods or services; loss of use, data, or profits; or
>>>> business
>>>> # interruption) however caused and on any theory of liability, whether
>>>> in
>>>> # contract, strict liability, or tort (including negligence or
>>>> otherwise)
>>>> # arising in any way out of the use of this software, even if advised
>>>> of the
>>>> # possibility of such damage.
>>>> # qemu
>>>> # use a qemu command to run the executable in the qemu simulator.
>>>> %include %{_configdir}/base.cfg
>>>> %include %{_configdir}/checks.cfg
>>>> # console.
>>>> %define console_stdio
>>>> %include %{_configdir}/console.cfg
>>>> # rtems version
>>>> %include %{_rtdir}/rtems/version.cfg
>>>> # qemu common option patterns.
>>>> -nographic
>>>> -nographic
>>>> #%define qemu_opts_base  -no-reboot -monitor null -serial stdio
>>>> -nographic
>>>> %define qemu_opts_no_net -net none
>>>> # qemu executable
>>>> %ifn %{defined bsp_qemu_opts}
>>>>  %define bsp_qemu_opts %{nil}
>>>> %endif
>>>> %define qemu_cmd  qemu-system-%{bsp_arch}
>>>> %define qemu_opts %{bsp_qemu_opts}
>>>> # Coverage analysis
>>>> %define coverage_arg %{nil}
>>>> %if %{defined _coverage}
>>>>     %if %{coverage_supported}
>>>>         %define coverage_arg -exec-trace %{test_executable}.cov
>>>>     %else
>>>>         %error "Coverage analysis unsupported for %{bsp}"
>>>>     %endif
>>>> %endif
>>>> # executable
>>>> #%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel
>>>> %{test_executable} %{coverage_arg}
>> Just get rid of  %{qemu_opts_base} (Theres a double count of options)
>> and that should run without errors from the tester now. Unfortunately the
>> report generated wont contain any data so we've moved on to problems in
>> covoar now.
> should I submit a patch now or should I apply the changes into current
> master and them submit ?
>>>> -nographic
>>>> -nographic
>>>> -nographic
>>>>>>> On 14 April 2018 at 20:37, Vijay Kumar Banerjee <
>>>>>>>> -- vijay
>>>>>>>> On 15 April 2018 at 00:50, Vijay Kumar Banerjee <
>>>>>>>>> On 14 April 2018 at 16:42, Cillian O'Donnell <
>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>> On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>>>>> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>> Getting this error now seems like something is missing.
>>>>>>>>>>>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>>>>>>>>>>>> Coverage environment prepared
>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>    File
>>>>>>>>>>>> "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test", line
>>>>>>>>>>>> 40, in <module>
>>>>>>>>>>>>      rt.test.run()
>>>>>>>>>>>>    File
>>>>>>>>>>>> "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py", line
>>>>>>>>>>>> 353, in run
>>>>>>>>>>>>      tst.reraise()
>>>>>>>>>>>>    File
>>>>>>>>>>>> 160, in reraise
>>>>>>>>>>>>      _test_reraise(*self.result)
>>>>>>>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>>>>>>> The reraise logic was moved to the rtemstoolkit last year:
>>>>>>>>>>> https://git.rtems.org/rtems-tools/commit/?id=fa81491764861e63785a3faa241c488469087209
>>>>>>>>>>> It had some issues that have been fixed and it is being reused
>>>>>>>>>>> else where in the tester.
>>>>>>>>>>>> -- vijay
>>>>>>>>>>>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <
>>>>>>>>>>>> vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>     On 13 April 2018 at 23:51, Cillian O'Donnell <
>>>>>>>>>>>>     <mailto:cpodonnell8 at gmail.com>> wrote:
>>>>>>>>>>>>         Hmmm it's not there. Even so I can almost guarantee
>>>>>>>>>>>> you, the
>>>>>>>>>>>>         reason it's not running is that coverage_supported
>>>>>>>>>>>> variable is
>>>>>>>>>>>>         not being found as true in qemu.cfg and so the the
>>>>>>>>>>>> command to
>>>>>>>>>>>>         generated the trace files isn't run and there's no .cov
>>>>>>>>>>>> files in
>>>>>>>>>>>>         the end. So that's what you'll have to dig into.
>>>>>>>>>>>>     Okay , I'll set it to global then.
>>>>>>>>>>> Changes need to be on the latest version of master before I will
>>>>>>>>>>> review them. The failure above indicate the code you have is not up to date.
>>>>>>>>>> Yes that was the plan. Just to check Vijay your starting point
>>>>>>>>>> was using the ini-update branch from here?
>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>> That branch is current rtems-tools master that I started to add
>>>>>>>>>> things back in. The only reraise in there is the one improrted from
>>>>>>>>>> rtemstoolkit.
>>>>>>>>> yes this is the branch I'm using , I checked the reraise error , not
>>>>>>>>> sure how it showed up buit I called it from the reraise module ,
>>>>>>>>> and it got fixed . now I'm stuck here
>>>>>>>>> error: config error: qemu.cfg:36: No 'target' defined
>>>>>>>> okay , fixed that .
>>>>>>>> still getting the warnings of the unable to read .cov
>>>>>>>>> are we supposed to set the bsp to global as well ?
>>>>>>>>>>> The change you have made is generating an exception in the
>>>>>>>>>>> tester thread. If you want to continue down this path you will need to fix
>>>>>>>>>>> what ever you have added.
>>>>>>>>>>> The tests are run as threads separate from the main thread so
>>>>>>>>>>> the exception is caught and re-raised in the main thread letting you know.
>>>>>>>>>>> This is broken in the old code base you are using.
>>>>>>>>>>> Why not investigate the reason as indicated and sort if out what
>>>>>>>>>>> the new format configuration file needs?
>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180416/25e4e76d/attachment-0002.html>
