the generated coverage report doesn't contain any data
Cillian O'Donnell cpodonnell8 at gmail.com
Mon Apr 16 20:13:08 UTC 2018
On 16 April 2018 at 17:46, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Apr 16, 2018 at 2:33 AM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> current status :
>> the coverage is running now with rtems-test and generating the report,
>> however, the report doesn't show any data.
> I've been lurking as you have been making progress. Now you have crossed
> into something you probably need some hints at. Some things to check:
> + Obviously, check output for signs that something didn't happen right.
> Anything from a path wrong, etc. The configuration has to be right to
> point to the source code, object code, executables, etc.
> + A lot of source code has moved around since last summer. Check
> that it is looking in the right places inside RTEMS.
> + Does the mechanism to get debug information actually work? Cillian?
The covoar debug option just disables the cleaning of the tempfiles to take
a look, so it's not as powerful as it might seem :)... I always used gdb
here so that's probably the way to go.
> + There is a utility named trace-converter. Make sure your qemu traces
> have information in them.
> + Cillian probably has guidance on running it just on one test (say ticker)
> so you can see every step.
> + Check that the executables have symbolic information. "file" should
> show if they are stripped or not.
> I recall covoar has a verbose mode which should be of use.
> Cillian .. do you have instructions on running covoar in gdb?
Alright so run rtems-test with --no-clean option to leave the coverage
files lying around
$HOME/development/rtems/test/test/rtems-tools/tester/rtems-test
--rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
--rtems-bsp=leon3_qemu --coverage --no-clean
--rtems-builddir=$HOME/development/rtems/leon3
sparc-rtems5/c/leon3/testsuites/samples
Then run
gdb covoar
from gdb prompt
run -S /home/cpod/coverage_test/leon3/coverage/score.symcfg -O
/home/cpod/coverage_test/leon3/test/score -fQEMU -Tsparc-rtems5
-E/home/cpod/development/rtems/test/test/vijay/rtems-tools/tester/rtems/testing/coverage/Explanations.txt
-c.cov -eexe -pRTEMS-5
/home/cpod/development/rtems/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe
The options there are ( if you're wondering )
 -c COVERAGEFILE_EXTENSION EXECUTABLE1 ... EXECUTABLE2
 -v                  - verbose output
 -T TARGET           - architecture target name
 -f FORMAT           - simulator format
(RTEMS, QEMU, TSIM or Skyeye)
 -E EXPLANATIONS     - file of explanations
 -s SYMBOLS_FILE     - symbols of interest
 -S SYMBOL_SET_FILE  - path to symbol_sets.cfg
 -1 EXECUTABLE       - executable to get symbols from
 -e EXE_EXTENSION    - suffix for executables
 -c COVERAGEFILE_EXT - coverage file suffix
 -g GCNOS_LIST       - list of *.gcno files
 -p PROJECT_NAME     - name of the project
 -O Output_Directory - output directory default=.
 -d debug            - disable cleaning of tempfiles.
Just trying it there, it runs into segmentation fault. So trying to access
memory it shouldn't.
Starting program: /home/cpod/covoar -S
Reading configuration symbol set file:
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7b769bb in std::__cxx11::basic_string<char,
std::char_traits<char>, std::allocator<char>
>::basic_string(std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> > const&) ()
   from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
Ahhh feels good to have error messages back.
Oh also build covoar with no optimization and you'll have an easier time
looking at stuff in gdb
cd rtems-tools/tester/covoar
vim wscript and change the '-O2' to '-O0' and then build again with waf and
use that covoar to with gdb
>> -- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180416/652bd351/attachment-0002.html>
