[PATCH 1/2] covoar: Add symbol set reader and ELF data parser to covoar.
Cillian O'Donnell
cpodonnell8 at gmail.com
Fri Apr 27 08:01:09 UTC 2018
On Fri, 27 Apr 2018, 08:32 Chris Johns, <chrisj at rtems.org> wrote:
> On 27/04/2018 17:21, Cillian O'Donnell wrote:
> > On Fri, 27 Apr 2018, 04:48 Chris Johns, <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 27/04/2018 08:51, Joel Sherrill wrote:
> > > // Create the set of desired symbols.
> > > SymbolsToAnalyze = new Coverage::DesiredSymbols();
> > > - SymbolsToAnalyze->load( symbolsFile );
> > > I am having trouble seeing what happened to the DesiredSymbols
> class. Is
> > > it no longer needed?
> > It's still being used as before, the decision has just been split from
> did you
> > provided the symbols file or are you using symbol_set.cfg file.
> DesiredSymbols
> > is definitely still being used. I'm looking on my phone so maybe missing
> > something that would be clearer not on a phone.
> I have renamed a few files, for example ..
> tester/rtems/testing/coverage/symbol_sets.cfg ->
> tester/rtems/testing/coverage/score-symbols.ini
> and that file now contains:
> [symbol-sets]
> sets = score
> [score]
> libraries=@BUILD-PREFIX@/c/@BSP@/cpukit/score/libscore.a
Fantastic, that solves the build path problem. Thanks.
> I have added code to get the build path, BUILD-PREFIX and BSP from the
> executable's path and check each executable is from the same build tree.
> I may check these against the RLD's automatically detected values after
> loading
> the libraries.
> I have add the code to load the libraries and the required symbols.
> This means some of the code to read the sets and then load the libraries
> and
> create a symbol file can be removed.
Ah ok, yes I see.
> I have not attempted to build to the code and will do this over the
> weekend or
> next week.
> > Just to update, I didn't get time to look at the rsb build yesterday so
> it'll
> > have to be tonight. Sorry for the delay, my new job keeps me very busy
> during
> > the week, long commutes too.
> No problem, when you can.
> Thank you.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180427/89b0ce85/attachment-0002.html>
